Topic: SUGGEST A MOTOR (Read 220 times) previous topic - next topic
excuseimanewbie
I'm planning to build an automatic swing gate opener.
Suggest a motor which i can use for the swing gate. 3 to 4 kg max open weight.
Robin2
What is a swing gate?    A diagram of the proposed device would be a big help - include dimensions.  See this  Simple Image Guide
How do you envisage connecting the motor to the gate?
How quickly does the gate need to open or close? More speed requires more power.
How will the motor be powered?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Paul_KD7HB
Why don't you suggest the power you will use for the motor?
Paul
MorganS
Outdoors? Then weather protection is more important than the motor power. Get one that is specifically designed for this task. It won't be cheap.
How far is this gate from the power source? What is your power source?
"The problem is in the code you didn't post."
khaledeeebuet
If it's just a demo project and you aren't serious about weather protection, you can use a 12V 600mA 2 rpm worm gear high torque (10 kg-cm) DC motor like this
hammy
#5
Jul 13, 2018, 08:21 pm Last Edit: Jul 13, 2018, 08:27 pm by hammy
Was this the earlier query about using servos to open a gate ? Have you googled gate openers to get an idea about driving systems ?
What about a car windscreen motor and gearbox ?
