Topic: Touchscreen ILI9486 uninitializes with no reason (Read 228 times) previous topic - next topic
Quantin_
Hello,
I recently started using touchscreens, I bought a 3.5" TFT shield, and after some issues with librairies I finally got some results with the MCU friend librairy.
I wrote a program who shows a menu and a page if we click on a text of the menu.
The problem is : for come back to the menu, I should end the "Resorcs" void doing a "break;" in a while (see program below)
But when I click on "back", I see a white screen.
While searching, I figured out that we actually uninitializes the screen when we click "back", so I have to reinitialise it, and that's a waste of time...
Do anyone have already had this problem ?
(Sorry for bad english and for the badly written program)
#include <Adafruit_GFX.h> // Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
uint8_t YP = A3;  // must be an analog pin, use "An" notation!
uint8_t XM = A2;  // must be an analog pin, use "An" notation!
uint8_t YM = 9;   // can be a digital pin
uint8_t XP = 8;
uint16_t TS_LEFT = 128;
uint16_t TS_RT  = 894;
uint16_t TS_TOP = 949;
uint16_t TS_BOT = 108;
uint16_t identifier;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
TSPoint tp;
bool BT = false;
int Antiretour = 0;
    TSPoint tp;
    #define MINPRESSURE 20
    #define MAXPRESSURE 1000
    tft.reset();
    identifier = tft.readID();
    if (identifier == 0xEFEF) identifier = 0x9486;
    tft.begin(identifier);
    tft.invertDisplay(true);
    tft.setRotation(3);
    tft.fillScreen(0x0000);
    Serial.println("MCDU V1");
    uint16_t x = 50, y = 100;
    if(Antiretour == 0) menu();
    uint16_t xpos, ypos;
    tp = ts.getPoint();   //tp.x, tp.y are ADC values
    pinMode(XM, OUTPUT);
    pinMode(YP, OUTPUT);
    pinMode(XP, OUTPUT);
    pinMode(YM, OUTPUT);
    if (tp.z > MINPRESSURE && tp.z < MAXPRESSURE) {
      if((tp.x < 500) && (tp.x > 350) && (tp.y < 500)){
         ThrSetup();
      else if((tp.x < 750) && (tp.x > 600) && (tp.y < 500)){
         Checklist();
      else if((tp.x < 500) && (tp.x > 350) && (tp.y < 1000) && (tp.y > 650)){
         State();
      else if((tp.x < 750) && (tp.x > 600) && (tp.y < 1000) && (tp.y > 600)){
         Resorcs();
void menu(){
  Serial.println("Menu");
  Antiretour = 1;
  tft.setCursor(120, 20);
  tft.setTextSize(5);
  tft.println("MCDU_001");
  tft.setCursor(10, 125);
  tft.setTextSize(3);
  tft.println("- THR SETUP");
  tft.setCursor(10, 225);
  tft.println("- CHECKLIST");
  tft.setCursor(345, 125);
  tft.println("STATE -");
  tft.setCursor(310, 225);
  tft.println("RESORCS -");
void ThrSetup(){
  Serial.println("Throttle Setup");
   Antiretour = 0;
   tft.setTextSize(5);
   tft.println("THR SETUP");
   tft.setCursor(100, 200);
   tft.setTextSize(2);
   tft.println("Feature not implemented yet");
   delay(10000);
void Checklist(){
  Serial.println("Checklist");
   tft.setTextSize(5);
   tft.println("CHECKLIST");
   tft.setTextSize(2);
   delay(10000);
   Antiretour = 0;
void State(){
  Serial.println("State");
  Antiretour = 0;
  tft.setTextSize(5);
  tft.println("STATE");
  tft.setTextSize(2);
  delay(10000);
void Resorcs(){
  Serial.println("Ressources");
  Antiretour = 0;
  tft.setTextSize(5);
  tft.println("RESSOURCES");
  tft.setCursor(10, 120);
  tft.setTextSize(2);
  tft.println("CL power : ");
  back();
  while (!((tp.z > MINPRESSURE) && (tp.z < MAXPRESSURE) && (tp.x < 500) && (tp.x > 350) && (tp.y < 1000) && (tp.y > 650))) {
     tft.setCursor(150, 120);
     tft.setTextSize(2);
     tft.print("90");
    tp = ts.getPoint();
void back(){
  tft.setTextSize(3);
  tft.println("BACK -");
david_prentice
#1
Jul 12, 2018, 03:10 pm Last Edit: Jul 12, 2018, 03:12 pm by david_prentice
Please upgrade the MCUFRIEND_kbv library via the Library Manager.   Current Release is v2.9.8
Please study the "button_simple" example.   And the "TouchScreen_Calibr_native" example.
You should map getPoint() values to the screen pixel coordinates.
Life is simpler with Adafruit_GFX_Button
Your crash problem is due to getPoint() without restoring pinMode() in Resorce()
David.
Quantin_
I did not think it was necessary, it works again, thank you :)
david_prentice
Design your project e.g. what each screen should look like.   what each button should do.
A rough pencil drawing is fine.   Post photos.
I will help you to use Adafruit_GFX_Button
The  "button_simple" example is easy to understand.
There is an alternative method in the other TAB.   This is far more useful when you have multiple screens with multiple buttons.
David.
