Topic: arduino not uploading board problem! (Read 465 times) previous topic - next topic
Archut
Jul 12, 2018, 04:51 pm Last Edit: Jul 12, 2018, 05:02 pm by Archut
so this i the first time in my 4 yrs arduino usage that the arduino is not able to upload sketches to atmega.
i have been using the original one and i even one powers it directly to 12v 10a which resulted in only the ic being burnt(Ps. the power of original).this happened 3 months ago and since was urgent i bought my first uno clone from a local shop.
so just yesterday i was using the clone with a custom shield which converts female headers to male and has l293d mounted which need jumpers to connect to uno digital pins only the vin and ground are connected to it over copper layer.
i uploaded the stepper example and disconnected the clone from computer and gave it 12v 1a dc supply to uno and not shield.
it did work correctly but resulted in burning the ic but what really happened is the uno's rx tx got burnt what i think since even after replacing the ic i can't upload though that ic works with usb ttl and original uno.
Archut
i am unable to publish the error code it says exceeds 9000 characters even after removing half error for different post
spycatcher2k
So attach the error as a txt file. But if you blew it up, and you know you have,  what are you asking? I see no question.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
Archut
thanks @spycatcher but this is what i think that the tx and rx are destroyed and i need a way to revive them
and how do i think that is simply because if i upload any code to the atmega and install it in the clone it works such as blink has been tried.
and here is the attached pdf
spycatcher2k
Quote
Why did you attach a PDF file? When I CLEARLY asked you to post a txt file?
I can't open PDF files where I am, so good luck if someone else decides to help!
What chip is on your board for the USB? Are you accomplished in SMD soldering? Can you get parts?
Do you have a Serial to USB converter to use, just hook it up to upload your code.
Mrs Drew
Archut
#5
Jul 12, 2018, 09:12 pm Last Edit: Jul 12, 2018, 10:09 pm by Archut
well i have the clone with removable atmega
and yes i have usb ttl and have accomplished in programming atmega using it but i want the uno to do that
that is work like normal
Archut
Archut
spycatcher2k
#8
Jul 15, 2018, 10:15 pm Last Edit: Jul 15, 2018, 10:16 pm by spycatcher2k
Replace the SMD chip used for the USB!
AS I told you to do in reply #4.
Mrs Drew
Archut
That seems to be a pretty bad advice since its atmel 16u2 hard to find
kprims
Have you tried to replace the firmware on the atmega16u2? Can you use the original Uno as "Arduino as Isp" and flash the atmega16u2?
https://www.instructables.com/id/How-to-Restore-the-Arduino-UNO-R3-ATmega16U2-Firmw/
http://forum.arduino.cc/index.php?topic=270995.0
