Topic: plz help me  (Read 288 times) previous topic - next topic
ZN2931
i have a problem which is i cant connect the cytron ps2 dualshock shield to my arduino uno. what should i do? do i need to connect the tx and rx first? i also use <Cytron_PS2Shield.h> as my library but i dont really understand how to use the library. plz i need answer ASAP.
i have sent the shield image. plz i need some help ASAP.
PaulS
Quote
Why can't you?
Quote
Most libraries come with examples. Doesn't that one? Most of the time, when you use a non-core library, you need to post a link to it. This time is not an exception.
Quote
With spelling and grammar, obviously.
ZN2931
Code: [Select]
Original written by:
            Cytron Technologies
Modified:
  29/06/15  Idris, Cytron Technologies    - Point to IDE SoftwareSerial
                                          - Restructure the code style to follow standard Arduino library
#ifndef Cytron_PS2Shield_h
#define Cytron_PS2Shield_h
#include "Arduino.h"
#include <SoftwareSerial.h>
// Arduino Leonardo
#if defined (__AVR_ATmega32U4__)
  #define Serial Serial1
#else
#endif
// Define PS2 button to number
enum {
  // Digital button
  #define PS2_SELECT
  #define PS2_JOYSTICK_LEFT
  #define PS2_JOYSTICK_RIGHT
  #define PS2_START
  #define PS2_UP
  #define PS2_RIGHT
  #define PS2_DOWN
  #define PS2_LEFT
  #define PS2_LEFT_2
  #define PS2_RIGHT_2
  #define PS2_LEFT_1
  #define PS2_RIGHT_1
  #define PS2_TRIANGLE
  #define PS2_CIRCLE
  #define PS2_CROSS
  #define PS2_SQUARE
  // Analog button
   PS2_JOYSTICK_LEFT_X_AXIS
   PS2_JOYSTICK_LEFT_Y_AXIS
   PS2_JOYSTICK_RIGHT_X_AXIS
   PS2_JOYSTICK_RIGHT_Y_AXIS
   PS2_JOYSTICK_LEFT_UP
   PS2_JOYSTICK_LEFT_DOWN
   PS2_JOYSTICK_LEFT_LEFT
   PS2_JOYSTICK_LEFT_RIGHT
   PS2_JOYSTICK_RIGHT_UP
   PS2_JOYSTICK_RIGHT_DOWN
   PS2_JOYSTICK_RIGHT_LEFT
   PS2_JOYSTICK_RIGHT_RIGHT
  // Check connection status
  #define PS2_CONNECTION_STATUS
  // Control motor vibrarion
   PS2_MOTOR_1
   PS2_MOTOR_2
  // Read all button
   PS2_BUTTON_JOYSTICK
class Cytron_PS2Shield
  public:
   boolean SERIAL_ERR;
   uint8_t ps_data[6];
    uint8_t _txpin, _rxpin;
    // Software Serial
    Cytron_PS2Shield(uint8_t rxpin, uint8_t txpin);
    // Hardware Serial
    Cytron_PS2Shield();
    void begin(uint32_t baudrate);
    uint8_t readButton(uint8_t key);
    boolean readAllButton();
    void vibrate(uint8_t motor, uint8_t value);
    void reset(uint8_t reset);
  protected:
    boolean hardwareSerial;
    SoftwareSerial *PS2Serial;
    void write(uint8_t data);
    uint8_t read(void);
#endif
#include <Servo.h>
 pinMode(13, OUTPUT);
 pinMode(12, OUTPUT);
 pinMode(11, OUTPUT);
 int jlyu = analogRead(PS2_JOYSTICK_RIGHT_X_AXIS);
 if(jlyu < 25){
  digitalWrite(11, HIGH);
  digitalWrite(12, LOW);
  for(int m = 1022; m < 1023; m++)
   digitalWrite(13, m);
   delay(10);
 else if(jlyu > 235){
  digitalWrite(11, LOW);
  digitalWrite(12, HIGH);
   delay(10);
 else{
