Topic: Attiny85 timer control (Read 519 times) previous topic - next topic
Frapeno
Timer / Delay:
a) one "Pin 0"  for "Signal IN" to be High level
b) one "Pin 1" for "Relay control", to be "ON/Off" after 30/60 second
c) one "Pin 2" for "LED" , counter flash + indicate Signal In is present.
d) one "Pin 3" for "Switch" - "Timer / Delay" selection
e) one "Pin 4" for "Switch" - "30s / 60s" selection, and flash Led.
Functioning way:
Timer Mode:
1st) If switched in "Timer mode", High level
2nd) If has "Signal 5v" into pin, then ....
3rd) Will power On the "Relay", then starts to count by flashing the "Led" 30s or 60, depending of the Switch 30/60s position.
4th) After reach the timer 30/60s, then will "Turn OFF" and keep off till reset the device or take Signal out and back.
Delay Mode:
1st) If switched in "Delay mode", Low level
3rd) WAIT, Will 1st starts to count by flashing the "Led" 30s or 60, depending the Switch 30/60s position.
4th) After reach the time 30/60s, then will "Turn ON" and keep on till reset the device or cut signal.
Remarks:
# The fucntioning will just start when has "Signal IN" on device.
# If cutted the signal, the device will be in "Stand by" condition, "relay off".
# Led, has 2 action, (one to flash during the counting seconds 30/60). Another is that after end the count, will keep flashing every 3 second, just to inform has "Signal in" present.
