Topic: How do I control 16 servomotors? (Read 263 times) previous topic - next topic
FRI3ND
I want to build a spider; each leg should have two joints.
So I have to control 16 servomotors; can I use shift registers (74HC595) for that?
slipstick
There are several Arduinos that have plenty of pins to allow control of 16 servos in the conventional way. No shift registers needed.
There is also an Adafruit 16 servo board that allows them to be controlled via I2C so very few pins are required. https://www.adafruit.com/product/815
Steve
vinceherman
#2
Jul 12, 2018, 08:05 pm Last Edit: Jul 12, 2018, 08:05 pm by vinceherman
Standard RC hobby servos?  The typical way to do that is with a servo board.
https://www.aliexpress.com/item/16-Channel-12-bit-PWM-Servo-Driver-I2C-interface-PCA9685-for-arduino-or-Raspberry-pi-shield/32710084048.html
These have the advantage of giving you and easy way to connect power to the servos independent of the arduino.
Grumpy_Mike
Quote
No.
hammy
I'm sure there was a post for a spider with servos about 6 months back ?
Paul__B
