Topic: stand alone (Read 1 time) previous topic - next topic
johneb
I have put in a sketch to the 328 using my UNO and now want to remove this and put it into a stand alone project. Can anyone tell me what I need to connect on the 328 one the stand alone board please
John
spycatcher2k
Drew.
http://www.uk-pcb.co.uk - My UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. PM me for non repair or testing, 1 to 1 support and I will charge you - beware!
johneb
Hi Drew
Thanks for the reply. It think all that seems a bit complicated, all I want is what to wire up besides +5v,Gnd, input  and otput pins. Do I need the crystal? what other pins need to be connected
John
spycatcher2k
+5v - pins 7 and 20
Gnd - pins 8 and 22
Crystal to pins 9 and 10 (with 22pf caps) OR resinator
pin 1 to 5V through a 10k resistor
and your done  :)
Drew.
Drew.
johneb
Hi Drew
Thanks will try this
John
johnwasser
It is possible to use the internal 8MHz clock instead of a crystal.  The fuse settings will be different to enable the internal clock.  I found this set of settings that is supposed to be put into boards.txt to allow installing a bootloader and sketches on an ATmega328 without a crystal or resonator.  I have not tried it myself.
atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
atmega328bb.upload.protocol=stk500
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xD9
atmega328bb.bootloader.extended_fuses=0x07
atmega328bb.bootloader.path=arduino:atmega
atmega328bb.bootloader.file=ATmegaBOOT_168_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino:arduino
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
CrossRoads
Schematic for reply #3, and pic of same installed with female header for making connections
johneb
John
