Pages: [1] 2   Go Down
Author Topic: Hacked mp3 player (basically an $8 waveshield)  (Read 3096 times)
I Biocowed an mp3 player and connected it to the arduino.  When I walk in the house, a motion sensor is activated and the mp3 player plays a welcome home song.
Biocow's original post is here, with a slightly different mp3 player: http://arduino.cc/forum/index.php/topic,49979.msg356317.html#msg356315
Here's a blurry photo of my dismantled mp3 player.
The buttons have an outer ring, and an inner ring.  When the two pieces of metal are connected, then it is a button press.
The only tricky part about controlling the mp3 player is soldering one wire to the inner ring, and soldering another to the outer ring.  Just add a bit of solder to each one.
The two wires are then connected to a transistor.  When the Arduino activates the transistor then the button on the mp3 player is connected.  IMPORTANT: the transistor needs a common ground connected to Arduino ground.
The button represents the button on the mp3 player.
After the soldering was done, I put hot glue over the wires and buttons to hold everything firmly in place, otherwise the wires would eventually detach.
I connected the Arduino to the pause/play button, which allows me to turn the mp3 player on and off with this particular mp3 player.  I also connected it to the forward button.
My mp3 player was purchased here: http://www.brilliantstore.com/4g-players-os-cpa-6184.html
Not a bad deal for $8.  It has 4 gigs of memory and comes with a cord to connect it to your computer.
// when I walk in the house a motion sensor is activated.
//The arduino turns on the speakers with a powerswitchtail.  Then
// it activates the mp3 player.  After playing the song for 1
// minute, the speakers are turned off.  Then the song is forwarded
// to the next one, and the mp3 player is turned off.
//A song will play every other time so that it doesn't play
// on exit, only entry.
int speaker = 0;         //powerswitchtail for speakers
int Forward =  13;    // forward 1
int Play = 8;          // play/pause
                       // LED on 6, motion sensor on 2
int del = 949;
int i;
int song=1;
long SongLength;
int motion = 1;
int entry=0;
void setup()   {
//Serial.begin(9600);
  // initialize the digital pin as an output:
  pinMode(Forward, OUTPUT);
  pinMode(Play, OUTPUT);
pinMode(6,OUTPUT);
pinMode(0,OUTPUT);
SongLength=10000;
digitalWrite(speaker,LOW);
{//949 delay and 150 press on the Forward buttons
//play
//200, shut off
motion=digitalRead(2);
if(motion==1){
  if(entry==1){
  //TURN IT ON
  digitalWrite(Play, HIGH);
  digitalWrite(6,HIGH);      //turn an led on
  delay(3500);
  digitalWrite(Play, LOW);
  digitalWrite(6,LOW);
  delay(5260);                //wait for the mp3 to come on
                            //4641 works, but small part of song
                            //4643 too short, misses
// TURN SPEAKERS ON
digitalWrite(speaker,HIGH);
//PLAY SONG
delay(60000); //1 minute
// TURN SPEAKERS OFF
 //GO FORWARD ONE SONG
 digitalWrite(Forward, HIGH);  //pass the current song
  delay(145);
  digitalWrite(Forward, LOW);
delay(300);                    // let it load in, (was del variable)
//TURN IT OFF
  digitalWrite(Play, HIGH);   //
  digitalWrite(6,HIGH);         //LED on
  delay(3500);
 delay(4000);
 entry=0;
  } else{
    entry=1;
    delay(20000);
  }//end entry if statement
} //END MOTION SENSOR IF STATEMENT
delay(100);
} // END MAIN LOOP
**UPDATE:
Good news.  I have found that the mp3 player can be powered from the 3.3v pin on the Arduino so that it doesn't have to be recharged.  Otherwise, you would have to charge it once a week.
It's pretty simple.  The battery is just stuck to the mp3 player with a bit of tape, it comes right off.  It's connected with red and black wires, power and ground.  I cut off the battery and soldered yellow wires to the red and black:
Here is the finished product, with yellow wires replacing the battery, red wires connected to the 'play' button, and green to the 'forward button, with hot glue over the whole thing to hold the wires in place (you could use tape instead of glue):
I posted some updated code below with more comments for readability.
« Last Edit: March 29, 2011, 11:00:53 am by Big Oil » Logged
Boston area, metrowest
Cool, ordered one myself!
Try this to get your arduino back for another project:
5V source is not shown
all parts available at www.dipmicro.com, maybe $10 for all
- atmega
- resistor
 - 3 100nF caps
 - 2 22pF caps
 - 16MHz crystal
- socket
- piece of perfboard to assemble on
Silly-con Valley, Ca, U.S.
Lernin' to tinker
LOL. I've become a verb!
Nice job. I've put mine aside for now but hope to resirect it with an AtTiny85 instead of an arduino.
10 PRINT CHR$(7)
20 GOTO 10
Nice work Big Oil, and credit to Biocow too.
North Yorkshire, UK
That's the only reason I visited this thread - too see why smiley-grin
I'm sorry but I am super new at this, and I have to recreate something similar to this.  Where do you hook up the motion sensor to?  Is this just an improvement to Biocow's so you don't have to use the relays?
cris11,
looking at the source code above, the line "motion=digitalRead(2);" appears to read the motion sensor input on digital pin 2.
Yes, it doesn't need relays.  The parts required are:
2 transistors (pins 13 and 8 with this code)
1 motion sensor (data input on pin 2), this one: http://www.adafruit.com/index.php?main_page=product_info&cPath=35&products_id=189
optional- 1 powerswitchtail (to turn the speakers off when not in use, on pin 0)
I've found that the mp3 player needs to be recharged once a week.  The wires to the battery are usable, so I'm looking at cutting into those and powering it off the arduino.  I'll update later.
I've cleaned up the code, removed some old junk from it, and added some more comments to make it easier for a beginner to read.
int Forward =  13;    // song forward
int Play = 8;          // play/pause a song
int motion = 1;
int entry=0;
void setup()   {
  pinMode(Forward, OUTPUT);     //to a transistor
  pinMode(Play, OUTPUT);         //to a transistor
pinMode(0,OUTPUT); //speaker
pinMode(2,INPUT);   //motion sensor input
digitalWrite(speaker,LOW); //speakers off
motion=digitalRead(2); // read motion sensor on pin 2
if(motion==1){  // if the motion sensor has been activated
  if(entry==1){  // entry goes from 0 to 1 and 1 to 0 every time that
                 // the motion sensor is activated.  It will only
                 // play a song every other time, when it's 1
  //TURN the MP3 player ON by pressing 'play' for 3 seconds
  delay(3500);
// TURN SPEAKERS ON
//PLAY SONG
delay(60000); //wait 1 minute while the song plays
  delay(145);
//TURN mp3 player OFF by pressing 'play' for 3 seconds
  delay(3500);
 delay(4000);
 entry=0;      // make 'entry' 0 so that next time it won't play a song
  } else{
    entry=1;   // else, next time play the song
    delay(20000);  //waits 20 seconds for the person to leave the house
delay(100);
} // END MAIN LOOP
« Last Edit: March 25, 2011, 11:36:26 am by Big Oil » Logged
Lernin' to tinker
Looks good.
BTW, the only reason I used relays is because I tried transistors but they didn't work. Tried relays and they worked. I later realized I didn't common ground the MP3 player and Arduino. DUH! But I actually liked the mechanical *click* of the relays.
10 PRINT CHR$(7)
20 GOTO 10
how about using optocoupler for activating the button? to me this is the cheapest and easiest option.
North Yorkshire, UK
transistors are easy, optos are easy.
For a beginner, optos are easier to understand but not normally cheaper.
Chester, UK
Trying to return the love to none logic level MOSFETS
What voltage does the mp3 player use through these switches?
If your system involves lethal voltages/life critical/flamable elements - you probably shouldn't need to ask.
The Arduino != PC.
It has a 3.7 volt battery so I measure around 2-3v.
I'm not able to keep the battery charged directly with the Arduino because it's a Lithium-ion battery.  It has to be recharged once a week.  I'm thinking about cutting off the battery entirely and just powering it with the 3.3 v pin on the Arduino.  I'll update later.
North Yorkshire, UK
I'd suggest that would be the best thing to do - I'd have thought it would be fine with 3.3V personally - make sure it doesn't require more than 50mA (if it's going to be powered off a duemilanove/old mega - 200mA I think if it's an uno/new mega - I'd go check that to be sure though)
Big Oil,
How did you open the MP3 player?
Mine finally arrived, I can't Windows Vista to recognize it, says a drive is removed, installed, removed, installed.
Any tips?
Thanks
Robert
Pages: [1] 2   Go Up
