Topic: programmer is not responding error (Read 975 times) previous topic - next topic
zill
Mar 19, 2011, 04:29 am Last Edit: Mar 20, 2011, 12:29 am by zill Reason: 1
My Arduino mini Nano has been working perfectly fine for over 2 years, but all of a sudden I got the following error upon programming it:
I didn't change anything hardware or software-wise. The same software/hardware setup was able to program it perfectly fine before.
When I try to program it the LED would blink exactly 3 times but then nothing happens (except the error). I'm experiencing the exact same error on Ubuntu 10.04 and Windows 7.
I don't have an ISP programmer or an other Arduino handy, so I can't re-burn a bootloader on there. Would buying an ISP programmer help the situation?
I realize this is a very common error message, but the previous threads were not helpful since my case is unique. All the other cases were people having problem programming their Arduino for the very first time.
Thank you for reading.
Coding Badly
Make absolutely certain the you have the correct board and serial port selected.
zill
Thanks for the response.
I have double checked that it's the correct board and serial port. I'm using Linux on a computer without serial port so there is only one serial port - ttyUSB0.
Coding Badly
CrossRoads
So maybe your USB to serial adapter is dead? You have something like an FTDI-Basic that you are using?
http://www.gravitech.us/arliandpropr.html
zill
Try a different (new) USB cable.
Thanks for the advice. I will try that on Monday when the local shops open.
Sorry, my bad. I have a Arduino Nano, not a Mini. I have corrected my original post.
