Topic: Upload by web browser ok but program no run  (Read 448 times) previous topic - next topic
LuisDarriba
My DUE doesn't run any sketch. I can upload the sketches fine but they don't run.
I tryed this hello world and nothing. It was working until yesterday.
I use the web browser IDE.
    Serial.println("hello")
ard_newbie
Did you select Arduino Programming Port and 9600 for the baud rate in Serial Monitor ?
After a power down, push the reset button to run the uploaded sketch.
LuisDarriba
9600 selected as well as programming port.
After I upload the program by usb cable throught programming port, I unplug the cable to switch off the board, then I plug it again and I push reset button, nothing change.
I tryed to run the builtin led example and it doesn't work neither.
I was working normaly until yesterday, I've uploaded and run my own sketch thousand times, but now it doesn't work.
ard_newbie
Very strange indeed.
Did you try to upload via the Native USB port and output via the Native USB port (modify your sketch accordingly and select Arduino DUE (Native USB port)) with the same result ?
LuisDarriba
Same result.
There are some comand to check every part of my board is working correctly?
The upload process works fine without any warming, but i cant diagnose the "run process", only with sketches that works or not.
ard_newbie
#5
Jul 15, 2018, 06:26 pm Last Edit: Jul 15, 2018, 06:27 pm by ard_newbie
You can select more options in Menu: File>Preferences.
Sometimes a faulty USB cable is responsible for the issue, but you said you uploaded successfully your sketch...
LuisDarriba
Tryed with other USB cable. Nothing new.
I use the wed IDE editor. Should i try with the old IDE? I don't find anything interesting to try in preferences.
LuisDarriba
Any other ideas to try?
I want to solve this issue to keep programing my project! =(
Maybe a method to debug if the program is running properly or some online diagnostic of the board?
