Topic: Ethernet Memory Leak --this thread has been replaced (Read 2063 times) previous topic - next topic
Beakie
Mar 19, 2011, 02:10 pm Last Edit: Mar 20, 2011, 09:34 pm by Beakie Reason: 1
I wrote some code using Visual C++ before putting it on the arduino (+ ethernet shield).
It worked in Visual Studio but when I put it on the arduino I got no response. I then removed a couple of functions to simplify it (hence the returns at the beginning of a couple of functions).... it now returns a page. But there is a memory issue as after the first call I get weird results.
Perhaps someone can tell me where this might occur. I am new to C++ (though work as a SQL/VB developer) so any useful critisism will be gladly taken on board. I am currently trying to get my head around the way c++ deals with memory.
Thanks
G
Beakie
I forgot to say that the code takes a web page request and parses it before returning a page. I think it will be to do with the HTTPRequest struct... but u tell me
PaulS
  char cReturn[10000];
None of the Arduinos has enough SRAM for a 10000 byte array.
Beakie
Quite right. Thanks for that.
I changed all the arrays to much smaller arrays so I don't exceed the 1024 max sram allowance... but it still doesn't work. And it fails in exactly the same way. The first 5 requests for pages work but the next few return dodgy results.
Anything else you feel could be causing the problem?
robtillaart
Do you have code to share? might be helpfull
Rob Tillaart
Beakie
The code is attached to my first post... but here is the latest version.
robtillaart
#6
Mar 20, 2011, 04:07 pm Last Edit: Mar 20, 2011, 04:54 pm by robtillaart Reason: 1
missed that, sorry.
-- update --
a quick scan:
char* HTMLEncode(char* _Text)
  char cReturn[200];
  unsigned int iReturn = 0;
  for (int iLoop; iLoop <= strlen(_Text); iLoop ++)
    switch(_Text[iLoop])
      case '\n':
        cReturn[iReturn] = '<'; iReturn++;
        cReturn[iReturn] = 'b'; iReturn++;
        cReturn[iReturn] = 'r'; iReturn++;
        cReturn[iReturn] = '/'; iReturn++;
        cReturn[iReturn] = '>'; iReturn++;
        break;
      case '<':
        cReturn[iReturn] = '&'; iReturn++;
        cReturn[iReturn] = 'l'; iReturn++;
        cReturn[iReturn] = 't'; iReturn++;
        cReturn[iReturn] = ';'; iReturn++;
        break;
      case '>':
        cReturn[iReturn] = 'g'; iReturn++;
        break;
      case '"':
        cReturn[iReturn] = 'q'; iReturn++;
        cReturn[iReturn] = 'u'; iReturn++;
        cReturn[iReturn] = 'o'; iReturn++;
        break;
      case '&':
        cReturn[iReturn] = 'a'; iReturn++;
        cReturn[iReturn] = 'm'; iReturn++;
        cReturn[iReturn] = 'p'; iReturn++;
        break;
      case ' ':
        cReturn[iReturn] = 'n'; iReturn++;
        cReturn[iReturn] = 's'; iReturn++;
        break;
      default:
        cReturn[iReturn] = _Text[iLoop];
        iReturn++;
        break;
  return cReturn;
Above function is faulty. It returns a pointer to a local variable of a function. After the call to this function the stack/heap space will be overwritten by other functions etc so the pointer points to something undefined at best :(
void AddNameValue(char* Key, char* Value, char*** KeyArray, char*** ValueArray, int* ArrayLength)
  char** tmpKeys = (char**)realloc(*KeyArray, (*ArrayLength + 1) * sizeof(char*));
  char** tmpValues = (char**)realloc(*ValueArray, (*ArrayLength + 1) * sizeof(char*));
  if (tmpKeys)
    *KeyArray = tmpKeys;
  if (tmpValues)
    *ValueArray = tmpValues;
// if (!keys || !values)
// return false; // out of memory
  (*KeyArray)[*ArrayLength] = strdup(Key);
  (*ValueArray)[*ArrayLength] = strdup(Value);
  ++(*ArrayLength);
Why are you using two  char *** params  (I've only used three levels of indirection at school)   Can you explain that?
  void HandleQueryStringLine(char* _QueryStringLine)
return;
This function (normally) uses two large arrays but after the call these arrays are gone as they are local variables.
void DoEthernet(void (*f)(Client, HTTPRequest))
  Client HTTPClient = server.available();
  unsigned int iInputIndex = 0;
  char cReceived[300];
  if (HTTPClient)
    boolean currentLineIsBlank = true;
    while (HTTPClient.connected())
      if (HTTPClient.available())
        char c = HTTPClient.read();
        cReceived[iInputIndex] = c;
        iInputIndex++;
        if (c == '\n' && currentLineIsBlank)
          HTTPRequest h; //should i do a free here and malloc at char cReceived[..]? Would need init to do malloc at beginning to stop memory error???
          h.Init();
          h.Parse(cReceived);
          f(HTTPClient, h);
          break;
        if (c == '\n')
          if (c != '\r') { currentLineIsBlank = false; }
    delay(1);
    HTTPClient.stop();
If there is text on a line currentLineis Blank will be made false and the if will never be true again. (or??)
Conclusion - after a quick scan and compile (not runned the code):
- I cannot get an overview from the code how it works (or is intended). For me that implies the architecture is complex (= my opinion).
- You do very much (imho too much) with pointers, that is ok but you have to take care that you free the allocated memory. Especially before reassigning new values to a pointer to a pointer .... Advice: - rewrite the code with as less pointers as possible - e.g. use fixed global array's, that makes the function calls far simpler ...
Rob Tillaart
Beakie
missed that, sorry.
s'all good. please lemme know if u see anything wrong
dafid
strdup() wraps up memory allocation and copying..
Your struct Page has strdup() in its constructor (page.h), and no destructor - so these are memory leaks.
Your DoResponse(...) (WebServer.pde) creates a Page and uses strdup() to also leak memory.
So your program will crash quite quickly.
You have two alternatives
1 - do not use strdup(), just assign the string to the pointer.
2 - or make sure you free the old pointer before replacing it, and free it in the destructor.
There is a lot of code, and I am not familiar with the environment, so this is probably not all of the problems.
Beakie
Thanks for your input. Considering what you said...
Question 1:
Looking at the code below. If I set PageTitle as "Title" (PageTitle being a char* within the struct) will c++ allocate the space to fit these 5 characters in for me? Do I need to free this space afterwards if I then set it to something else?
void DoResponse(Client _HTTPClient, HTTPRequest _Request)
  Page xPage;
  xPage.Init();
  xPage.PageTitle = "Title";
  xPage.Render(_HTTPClient);
Question 2:
The function that encodes for HTML. How SHOULD I achieve what I want?
I want to pass in a pointer to a string, create a space to put a new encoded string in (leaving the original untouched), and then return a pointer to that new string.
If I create the array like below, the memory will be destroyed after the function ends (right?) so how do I pass this back without requiring a call to free().
  char cReturn[200];
Thanks
Beakie
#10
Mar 20, 2011, 08:14 pm Last Edit: Mar 20, 2011, 08:16 pm by Beakie Reason: 1
OK
I was trying to pass a pointer to an "array of strings".
Thanks for your input. I appreciate this code might be a little complicated for someone asking basic memory questions/making basic memory errors but I am a big believer in jumping in the deep end with stuff like this. I stand by my design just not the code to do it :)
Beakie
I realised this code was too complicated so I simplified an example here...
http://arduino.cc/forum/index.php/topic,55969.0.html
Please comment there instead. It should make things easier.
