Loading...
Pages: [1]   Go Down
Author Topic: Using a devices LED AS a trigger. Suggestions please.  (Read 247 times)
US
Offline Offline
Newbie
What does this button do?
View Profile
If I wanted to use another devices LED as a trigger for the Arduino, what would be the options?
I know I can use a photo resistor to point at an LED and use its input on the Arduino as a trigger. But is there another way?
Can I clip on to the LED power and ground leads and get a reading from that on the Arduino? Or must the Arduino be in the circuit for that to work?
Thanks for any help.
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
It depends upon how that LED is wired up. If you're lucky enough that the LED has its cathode wired to ground and you can share a common ground with that circuit, you can just measure the voltage at the LED anode with an analog A/D input. It'll be 0 when the LED is off and quite a bit not 0 when the LED is on (probably in the 2-3V range, but could be as high as 4V or so for white LED's).
If you don't want to connect the circuits together, you can use an optodarlington to draw a bit of current from the LED (like an LTV-815) and switch an Arduino input to ground when the LED turns on (use the Arduino pull-up resistor to keep it high otherwise). You'll need a resistor in series with the optodarlington input to prevent too much current from going to it and making the LED dim. I'd start with 10k and go down as necessary.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Logged
Pages: [1]   Go Up
Print
Jump to:
