Topic: Powering 23 servos? (Read 1 time) previous topic - next topic
Geeko
What are my stationary options here? What is my mobile options?
I am powering 23 hitec servos, for now I just need something for a demo. Later on I need some kind of battery powered option.
Thanks in advance.
Grumpy_Mike
Before any answers can be given you need to know (and tell us) the voltage and current these servos require.
Geeko
Eh, stupid mistake. 4.8-6V, and I am unable to find current information. :/
Torque (Kg-cm/Oz-in @6V): 72/89 -- digital servo.
vinceherman
Do you have the model number from the servos?
Grumpy_Mike
Quote
Well you will need to know that, if not from the data sheet then from measuring it. It is also best to measure it under full load. Then multiply up by 23 to get the total load.
At a conservative guess of 200mA per servo then you have a total current of 4.6A which is quite a lot. For 5V this is 23 Watts.
So for mobile then a lead acid battery might be good, you could get the 6v motorcycle ones.
For fixed then you are looking to convert / use a PC's PSU.
Geeko
Current Drain (6.0V): 9.1mA/idle and 500mA no load operating
This is all I could find. All I need is 30 minutes of operating time.
Grumpy_Mike
Quote
Wow any idea of the current on load?
That puts the current at 11.5 Amps and for 30 mins will require a 6000mA Hour battery minimum. Probably a lot more given that they are going to be on load.
You are then into the calculation of duty cycles, that is, are all the motors on all the time. This will reduce your battery requirements or extend your time. But I am sure you can do the maths as well as me.
Geeko
Unfortunately this is a humanoid robot, none will be at full load but most of them will probably have 1/10 - 1/2 load constantly. I don't have anything at home to measure current. I'll have to purchase something some time.
Grumpy_Mike
You can get a cheap multi meter from a thrift shop for $5 so there is nothing to stop you.
Geeko
Yea, I got one but its strict voltage. -_- Junk. I hate it.
zoomkat
Quote
If you live in the US you can get reasonably decent multimeters for $5-$25. So if you are serious about building a humanoid bot, you need to get the required tools.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
