Topic: Where to put a library? (on linux) (Read 891 times) previous topic - next topic
robelix
Got the Tlc5940 library - but I can't build the examples - all I get is "fatal error: Tlc5940.h: No such file or directory"
So far I tried:
~/sketchbook/libraries
~/sketchbook/hardware/
~/sketchbook/hardware/libraries
~/.arduino/libraries
~/.arduino/hardware
~/.arduino/hardware/libraries
/usr/share/arduino-0021/libraries
/usr/share/arduino-0021/hardware
/usr/share/arduino-0021/hardware/libraries
9 of 9: "Tlc5940.h: No such file or directory"
Is there a way to show the include-path - and where or how can it be configured?
Robelix
baum
Hold on... just booting up my Ubuntu computer. Be back in a bit.
baum
This:
is where it should go. If you're in the right spot, you should see folders like "Wire" and "EEPROM." If you do, create a new folder called Tlc5940. Then, put all your files in there.
and where did u get the library from?
pluggy
#3
Mar 20, 2011, 10:03 am Last Edit: Mar 20, 2011, 10:06 am by pluggy Reason: 1
Bear in mind the IDE has to be restarted after making an addition to the libraries, it doesn't work until you do.
Quote
Assuming its installed in /usr/share/  mines in my home folder.
http://pluggy.is-a-geek.com/index.html
robelix
Thank you! - That's the thing i missed.
Quote
http://code.google.com/p/tlc5940arduino/downloads/list
