Topic: Square wave control voltage input (Read 886 times) previous topic - next topic
aranm
I would like to build a modular synthesiser component (im thinking a step sequencer) However I want this to be driven by an external control voltage clock signal. I have a LFO (in my eurorack modular system http://www.analoguesystems.co.uk/pdf/RS80%20&%20RS85%20manual%20lo-res.pdf) that outputs a square wave that is in the range +/- 5.0V I would like to be able to detect when I get the rising edge to drive a clock.
At first all I want to do is light up an LED to make sure I am getting the correct clock signal. Any thoughts?
RuggedCircuits
Quote
Get in line  :)
Quote
Just put the signal through a diode and connect it to a digital input (and, of course, connect the two system grounds together). When the output is +5V the digital input will read high, when it is 0V or -5V it will read low. You may want to also connect a 10k resistor from the digital input to ground to have it turn off faster.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
aranm
>> Get in line
(yeah but mine will be way cooler :)
Any thoughts on a protection mechanism if the voltage exceeds 5v?
RuggedCircuits
Quote
You can use a circuit like this to limit the voltage to 5V:
http://ruggedcircuits.com/images/sch44.png
The rectifier diode would come before the 1k resistor.
The Rugged Motor Driver: two H-bridges, more power than an L298, fully protected
