Topic: Error Message in Code (Read 422 times) previous topic - next topic
Jariana
Jul 20, 2018, 11:59 pm Last Edit: Jul 21, 2018, 12:09 am by Jariana
I am not understanding why I am receiving an error message for the portion of my code that is "highlighted" in red.  This is my first time writing code by myself and I am unable to interrupt what the error message is saying to me and how to fix it. The error message reads at the bottom of this post, underneath my code.  Can anyone help me, please?
int h[2]= {0000, 0001};
int s0 = 8;
int s1 = 9;
int s2 = 10;
int s3 = 11;
int s02 = 7;
int s12 = 6;
int s22 = 5;
int s32 = 4;
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(s02, OUTPUT);
pinMode(s12, OUTPUT);
pinMode(s22, OUTPUT);
pinMode(s32, OUTPUT);
  int val = analogRead(0);
for (int i = 1:2)
  r1 = h(i,1)
  r2 = h(i,2)
  r3 = h(i,3)
  r4 = h(i,4)
for j = 1:2
  r5 = h(i,5)
  r6 = h(i,6)
  r7 = h(i,7)
  r8 = h(i,8)
digitalWrite(s0, r1)
digitalWrite(s1, r2)
digitalWrite(s2, r3)
digitalWrite(s3, r4)
digitalWrite(s02, r5)
digitalWrite(s12, r6)
digitalWrite(s22, r7)
digitalWrite(s32, r8)
end
end
  Serial.print("Value at channel: ");
  Serial.print(val);
int s0 = 8;
int s1 = 9;
int s2 = 10;
int s3 = 11;
int s02 = 7;
int s12 = 6;
int s22 = 5;
int s32 = 4;
for (int i = 1:2)
  r1 = h(i,1)
  r2 = h(i,2)
  r3 = h(i,3)
  r4 = h(i,4)
for j = 1:2
  r5 = h(i,5)
  r6 = h(i,6)
  r7 = h(i,7)
  r8 = h(i,8)
end
end
  Serial.print(val);
ERROR:
/tmp/907409201/sketch_jul13a/sketch_jul13a.ino: In function 'void loop()':
/tmp/907409201/sketch_jul13a/sketch_jul13a.ino:39:3: error: 'r1' was not declared in this scope
/tmp/907409201/sketch_jul13a/sketch_jul13a.ino:39:13: error: 'h' cannot be used as a function
exit status 1
AWOL
#1
Jul 22, 2018, 08:58 am Last Edit: Jul 22, 2018, 09:01 am by AWOL
for (int i = 1:2)You really need to take a look at some of the worked examples in the IDE, paying particular attention to for loops, arrays, and {} braces (and scope).
Also, the e-textiles forum is not the most appropriate for this question - I'll move it to programming.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
UKHeliBob
  r1 = h(i,1)
  r2 = h(i,2)
  r3 = h(i,3)
  r4 = h(i,4)
Just few missing semicolons ...
PieterP
C++ is not Python. You have to follow the correct syntax. You have to declare your variables. You have to use braces around code  blocks. You have to use  semicolons. Please look up how to use for loops.
Pieter
PaulMurrayCbr
Ok. Your code is not actually valid C++ code. You need to go do a C++ tutorial and learn the syntax of the language.
Here's one: http://www.cplusplus.com/doc/tutorial/ .
http://paulmurraycbr.github.io/ArduinoTheOOWay.html
