Loading...
Pages: [1]   Go Down
Author Topic: Change clock frecuency (bootloader)  (Read 432 times)
Offline Offline
Newbie
View Profile
Hello everyone!
I have one Arduino Duemilanove board that works fine. This board has an ATMEGA328 that works at 16MHz and 5V.
I want to design a new board based on Arduino philosophy that will works at 3.3V. For this operation voltage I must to down clock frecuency.
I want that this new board has a bootloader like Arduino Duemilanove so I will can program directly from Arduino IDE.
Since original Arduino Duemilanove boards has a 16MHz I can not use the same bootloader for my board.
My question is how can I compile a bootloader with a different clock frecuency? If I change clock frecuency in bootloader source code and then I compile it, does it works?
Thanks in advance.
Regards.
PD: Sorry for my horrible english
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Hello.
Instead of compiling the bootloader you may be able to use an existing one...
ATmegaBOOT_168_atmega328_pro_8MHz.hex
ATmegaBOOT_168_pro_8MHz.hex
LilyPadBOOT_168.hex
Select the Arduino that most closely matches your board and use its bootloader.
Or, westfw may be willing to give you a copy of an 8 MHz version of Optiboot for your board.
Logged
Offline Offline
Newbie
View Profile
Dear Coding Badly,
Thanks for your reply and advice. Few hours ago I finded something similar.
The idea to compile a new bootloader with different clock frecuency is that I only have 4MHz clock. If I don´t obtain the way to compile a specific bootloader I will try to adquire 8MHz clock. Thanks anyway.
Anyone can help me?
Thanks in advance.
Regards to all.
Logged
Gatineau, Qu
Offline Offline
Jr. Member
Did you Arduino today?
View Profile
You don't need to get a 8mhz clock. It's internal to the chip.
Logged
Pages: [1]   Go Up
Print
Jump to:
