Topic: Arduino Single-Sided Serial Board Boot Loader Problem (Read 2822 times) previous topic - next topic
sl33py
So, i made the single sided Serial Board(v3) and i try to burn the bootloader using the parallel port programmer ( i am using atmega8), the ide gives the following log:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA8 is 1E 93 07
***failed;
avrdude: verification error, first mismatch at byte 0x0000
         0xca != 0xff
avrdude: verification error; content mismatch
I also noticed that when i plug the ICSP connector the 'L' led lights up even when i have not connected the power, I was wondering if its a problem with my board or something else.
johnwasser
If you look at the schematic you will see that ICSP header is connected to +5, Gnd, Reset, SCK, MOSI, and MISO.  Pin 19 is both SCK  (the SPI serial data clock) and D13, the Arduino pin with the LED, so when the clock is high the light will be lit.
I have not used a parallel programmer (no parallel port on my MacBook) so I don't know what is causing the error.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
MarkT
It could be worth double checking the continuity from the ICSP header to the pins of the ATmega chip.
sl33py
ok i tinkered a bit and eventually got it to burn the bootlaoder, now when when i try to upload the blink sketch the following error shows up:
Binary sketch size: 1018 bytes (of a 32256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
any ideas?
johnwasser
It could be the auto-reset isn't working.  You did put in the auto-reset jumper, right?  Try a manual reset.  Hold down the Reset button and release it when the "Binary sketch size" message shows up.
sl33py
The auto reset jumper is in the right position, i tired uploading sketches using the icsp connector (with the parallel port) and it worked.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
