Arduino Code://Code on the actual mobile data logger
//Dino Tinitigan
//Controller
#include <NewSoftSerial.h>
#include <Servo.h>
NewSoftSerial mySerial(2, 3); //Serial Port for Motor Controller
Servo myservo;
//------------------definitions for pololu motor controller---------------
//Trex Jr Motor Controller
#define brkM1 192 //followed by 1 data byte
#define revM1 193 //followed by 1 data byte
#define fwdM1 194 //followed by 1 data byte
#define brkM2 200 //followed by 1 data byte
#define revM2 201 //followed by 1 data byte
#define fwdM2 202 //followed by 1 data byte
#define brkM 208 //followed by 2 data bytes
#define revM 213 //followed by 2 data bytes
#define fwdM 218 //followed by 2 data bytes
#define fM1rM2 214 //followed by 2 data bytes
#define rM1fM2 217 //followed by 2 data bytes
byte incoming;
byte checksum;
byte prevC;
int pos;
int at = 0;
int lTot;
int rTot;
int temp;
float d;
int hazard = 0;
float vRef = 4.80;
byte type;
int v1 = 100; //speed variables
int v2 = 50; //speed variables
Serial.begin(19200); //connected to XBee
mySerial.begin(19200); //connected to motor controller
myservo.attach(9); // attaches the servo on pin 9 to the servo object
pinMode(2, INPUT);
pinMode(3, OUTPUT);
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
myservo.write(90);
if(at==1)
automated();
//-------------movement commands----------------------//
if(Serial.available())
incoming = Serial.read();
if(incoming == 'X')
brake(64);
at = 0; //turn automated off
else if(incoming == 'W')
if(prevC!=incoming)
forward(v1);
prevC = 'W';
else if(incoming == 'S')
if(prevC!=incoming)
reverse(v1);
prevC = 'S';
else if(incoming == 'A')
if(prevC!=incoming)
hardLeft(v1);
prevC = 'A';
else if(incoming == 'D')
if(prevC!=incoming)
hardRight(v1);
prevC = 'D';
else if(incoming == 'Q')
if(prevC!=incoming)
forwardLeft(v1, v2);
prevC = 'Q';
else if(incoming == 'E')
if(prevC!=incoming)
forwardRight(v1, v2);
prevC = 'E';
else if(incoming == 'Z')
if(prevC!=incoming)
reverseLeft(v1, v2);
prevC = 'Z';
else if(incoming == 'C')
if(prevC!=incoming)
reverseRight(v1, v2);
prevC = 'C';
else if(incoming == 'U')
prevC = 'U';
at = 1; //turn automated ON
brake(64);
Serial.flush(); //flush the serial port
//-------------------Sensor Data----------------------//
sendLight();
sendTemp();
//delay(50); //delay to prevent overflowing the serial buffer
void forward(int spd)
mySerial.print(fwdM, BYTE);
mySerial.print(spd, BYTE);
void reverse(int spd)
mySerial.print(revM, BYTE);
void brake(int spd)
mySerial.print(brkM, BYTE);
void forwardRight(int spd1, int spd2)
mySerial.print(spd1, BYTE);
mySerial.print(spd2, BYTE);
void forwardLeft(int spd1, int spd2)
void reverseRight(int spd1, int spd2)
void reverseLeft(int spd1, int spd2)
void hardRight(int spd)
mySerial.print(fM1rM2, BYTE);
void hardLeft(int spd)
mySerial.print(rM1fM2, BYTE);
void automated() //Automated mode
hazard = 0; //default value
forward(v1);
int tot = 0;
for(int i = 0; i<5; i++) //get 5 readings and average it
temp = getRange();
tot = tot + temp;
delay(50); //delay to let sensor update with new data
temp = tot/5;
if(temp <= 8) //closer than 8 inches
sweep();
hazard = 1; //hazard found
if(hazard==1)
if(lTot > rTot)
boolean turning = true;
hardLeft(v1);
delay(1000); //initial turn delay
while(turning)
int dt = getRange();
if(dt >= 16)
//16 inch clearance found
forward(v1);
turning = false;
hardRight(v1);
while(turning)
if(dt >= 16)
forward(v1);
turning = false;
}//end of else
}//end of if
}//end of automated
void sweep()
lTot = 0;
rTot = 0;
brake(64); //make sure vehicle is stoppped before doing a sweep
for(pos = 0; pos < 180; pos += 2) //sweeps from 0 degrees to 180 degrees
myservo.write(pos);
delay(50);
temp = getRange();
if(pos>90)
lTot = lTot + temp;
rTot = rTot + temp;
//transmit data
type = 128; //128=>sonar data
checksum = temp + pos;
Serial.write(255); //header byte
Serial.write(type);
Serial.write(temp); //distance byte
Serial.write(pos); //angle byte
Serial.write(checksum); //checksum byte
myservo.write(90); //return to middle;
Serial.flush(); //flush serial port
int getRange()
//reads analog value from port and returns into a converted value in inches
int z = analogRead(0);
d = z*vRef*1000;
d = d/1024;
d = d/9.8;
z = (int)d;
return z;
void headLightsOn()
digitalWrite(13, HIGH);
digitalWrite(12, HIGH);
void headLightsOff()
digitalWrite(13, LOW);
digitalWrite(12, LOW);
int getTemp()
int totalT = 0;
double temp1;
int prevT;
//calculate initial value
temp1 = analogRead(2);
temp1 = temp1*1000; //millivolts factor
temp1 = temp1/1024; //10-bit range
temp1 = temp1*vRef; //vref
temp1 = (temp1-500)/10; //calculate temperature in Celcius
prevT = (int)temp1;
for(int i = 0; i<10; i++) //get an average of 50 readings to fix noise issue
if(temp1 >= (prevT+5)) //huge fluctuation
temp1 = prevT; //keep last value and discard invalid value
prevT = temp1;
totalT = totalT + temp1;
delay(5);
totalT = totalT/10;
return totalT;
void sendTemp()
type = 89;
int t1 = getTemp();
checksum = t1;
Serial.write(type); //ID byte
Serial.write(t1); //data byte
void sendLight()
int lightLevel = analogRead(1);
if(lightLevel <600)
headLightsOn();
headLightsOff();
type = 23;
lightLevel = lightLevel/4; //make the data fit into a byte
checksum = lightLevel + type;
Serial.write(lightLevel); //data byte
