Topic: Error Compiling (Read 1 time) previous topic - next topic
MechEngr396
I hooked up an Arduino Duemilanove Atmega328 with Windows XP for the first time. I tried to run the blinking LED code and I am getting the following error:
"Error Compiling"
core.a(main.cpp.o): In function `main':
C:\Documents and Settings\Laptop\My Documents\Arduino\arduino-0022\hardware\arduino\cores\arduino/main.cpp:10: undefined reference to `loop'
Can anyone help?
Coding Badly
Has to be an installation problem.  Try removing the Arduino software and reinstalling.
CrossRoads
Most likely a typo, missing semi colon, ), or } somewhere.
Post the code using the # shortcut,
or type in
[ code ]
copy  your sketch
[ /code ]
(without the spaces between the brackets)
we'll help you find it.
Coding Badly
Yikes!  Sorry about that.  Ignore my post and pay attention to the guy above.
CrossRoads
You may end up being right Coding - I just tried messing with the ( )s & { }s in the void loop area on a sketch I had open, got some errors, but none saying Compiler error like the OP showed.
MechEngr396
Found the problem
There was a typo when I called the loop.
Thanks
Coding Badly
Uh, you should not need to call loop.  You may want to post your Sketch for a some guidance.
Or do you mean "when I defined loop"?
