Topic: Car cruise control device (Read 1 time) previous topic - next topic
Snabark
Hello guys,
I am new to the world of arduino and electronics
I have corolla 2015 with out cruise control
My project is to make one for it
I figured all part of the subject but have single obstacle, is about the electronic speed paddle , it form of two potentiometers of 5 volt power ,each give different value with each degree of foot pressure.
I want to hack its cable and make the car think that the paddle is pressed.
I thought about arduino PWM and put low pass filter after it but this does not give steady output voltage , and I am afraid that the car will not respond to this.
Any help with that ?
Delta_G
Then you should probably do a LOT of learning before you start modifying a two thousand pound machine that moves at 70 miles per hour and has the potential to kill people.
The particular questions you are asking back that up.  You should probably not be messing with something that is safety critical until you have at least learned the basics.  Really you should be at the expert level for that, but let's at least get past the basics before we do anything that could cause someone to lose a life.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Snabark
thank you for your concern
An answer to the question may be more helpful...
Delta_G
#3
Jul 27, 2018, 04:36 pm Last Edit: Jul 27, 2018, 04:39 pm by Delta_G
Get people killed.
Why would anyone want to do that?  Go get to a level where you can do these things without asking basic questions and then take other people's lives into your hands.  Just don't do it around me.  You ever crash into me and I find out you modified your car with an Arduino without knowing what you were doing and it will be the end of you.  I will own everything you've ever had.
At least try it out on an RC car or something first.  Don't get people killed because you don't understand your own limitations.
|| | ||| | || | ||  ~Woodstock
AJB2K3
1, Learn how CC works,
2, learn what connections are required to make it work,
3 work out if your car supports it (consult ECU Specifications),
4, Find out what Wiring is available in car.
CC on post 2010 cars are controlled by the ecu and drive by wire.
There are quite a few safety systems that need to be understood in order to retrofit CC and dont forget that your car inspection centre must also approve of the setup before it can be used on public roads.
Sorry for the noobish post but my knowledge is 10 years out of date!
gsm3155
Hi everyone!
I was reading all the threads related to Cruise control and all I could read is safety concerns and that is genuine, but all I want to tell is we all are responsible that no one would drive the car on public roads, even after testing the system a million times. We all are here for learning and experimenting good and crazy stuff.
Cruise control is challenging, and if we gather all the information from everyone, we could learn something new!
It would be better to help us with the above-asked question and this (https://forum.arduino.cc/index.php?topic=484029.15) thread.
Paul_KD7HB
Hello guys,
Have you actually tested your theory with two separate manually operated potentiometers?
Paul
B1810seconds33
This would be tough but i'd image possible using VSS as input and APP being the output and tap the wiring into the vehicles system using a kill switch or 2 or 3.
You also have to make sure the Brake Switch kills the Loop. Adding Accel/Decel switches adds to mess. Coding to achieve a target is not something i'm experienced with yeat.
One way or another anyone thinking of doing something like this needs to test on a Breadboard first. This system should be fully testable on a bench...
