Germany
Offline
Newbie
« on: March 21, 2011, 11:00:05 am » |
Hy,
I just finished a LED Cube and thought LED's are good signes. How can I make my Arduino uno recieve E-Mails and RSS feeds, so he can lite a LED? Is USB ok or should I bui the ethernet shield?
Thanks Robohac
Logged
Germany
Offline
Newbie
« Reply #1 on: March 21, 2011, 12:55:43 pm » |
I found a Video, but there isn't written how he made this:
Logged
Germany
Offline
Newbie
« Reply #2 on: March 23, 2011, 11:09:45 am » |
Can't anyone help me?
Logged
Finland
Offline
Newbie
« Reply #3 on: March 23, 2011, 01:31:33 pm » |
I suppose that he said into video that PC sends info into arduino. So you could write python script that checks your email and then send results with serial into your arduino sketch.
-Jussi-
Logged
Germany
Offline
Newbie
« Reply #4 on: March 23, 2011, 03:50:00 pm » |
but how can I make the Scetch and the .py script comunicate?
Logged
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #5 on: March 23, 2011, 04:18:42 pm » |
Over the serial port?!! A sample python sketch that reads from the arduino may help to get you started import sys, os, serial
def monitor():
ser = serial.Serial(COMPORT, BAUDRATE, timeout=0)
while (1): line = ser.readline() if (line != ""): #print line[:-1] # strip \n fields = line[:-1].split('; ') ID = fields[0] # print fields print "device ID: ", ID # write to file text_file = open("Pdata.log", "w") text_file.write(line) text_file.close()
# do some other things here
print "Stop Monitoring"
""" ------------------------------------------- MAIN APPLICATION """
print "Start Serial Monitor" print
COMPORT = 4; BAUDRATE = 115200
monitor()
Logged
Germany
Offline
Newbie
« Reply #6 on: March 24, 2011, 07:32:52 am » |
but the arduino uno haves only a usb port should I replace serial with usb?
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #7 on: March 24, 2011, 07:51:27 am » |
but the arduino uno haves only a usb port should I replace serial with usb? It has a USB to serial converter on board so it appears as a serial port to your computer.
Logged
Germany
Offline
Newbie
« Reply #8 on: March 24, 2011, 08:07:05 am » |
woops sorry I didn't know that
Logged
Netherlands
Offline
Tesla Member
« Reply #9 on: March 24, 2011, 02:08:43 pm » |
Logged
Germany
Offline
Newbie
« Reply #10 on: March 25, 2011, 12:22:52 pm » |
is that pithon 2 or 3 ?
Logged
Netherlands
Offline
Tesla Member
« Reply #11 on: March 25, 2011, 01:46:52 pm » |
it compiles under my python 2.7 In the comments there is a ref to - http://snippets.dzone.com/posts/show/4024 - which is a more elaborate checker, includes sending mail too.
Logged
Rome
Offline
God Member
Arduino rocks
« Reply #12 on: March 30, 2011, 06:15:45 am » |
Hy,
Thanks Robohac
wihtout ethernet shield, your PC must be always on to retrieve emails and send them to Arduino. With ethernet shield you don't need any PC at all.
Logged
Germany
Offline
Newbie
« Reply #13 on: March 30, 2011, 06:32:29 am » |
But with ethernet shield I need a server. Or not? How should I programm that?
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #14 on: March 30, 2011, 07:29:43 am » |
How should I program that? With difficulty - You would need some kind of server (but if you have an email address then you probably have one you can access). You can probably monitor an imap server for new messages.
Logged
