Loading...
Pages: 1 [2]   Go Down
Author Topic: E-Mail / RSS checking LED  (Read 1475 times)
Rome
Offline Offline
God Member
Arduino rocks
View Profile
But with ethernet shield I need a server. Or not? How should I programm that?
If you do not need active pages (ASP, PHP,...), Arduino is the server: it reads request over the network, and it sends HTML pages as replies.
You can program Arduino in such a way that upon connecting to its IP from remote, it will reply with a web page containing a form which shows text and buttons; you click a button, and something is turned on/off at home.  smiley
If the page is very simple, it can fit in the little onboard memory. If you want to "serve" images and video, yuo'll need a microSD slot to hold the data.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
I was thinking more of without having a computer on all the time.
Logged
Rome
Offline Offline
God Member
Arduino rocks
View Profile
Quote
Then you definitely need an eth shield.
Just decide if you want to make availabale large files (microsd slot required) or just some data.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Well I don't - the OP does.
Quote
You really haven't read the thread properly have you?
They want to have Email notification...
Logged
Minnesota!
Offline Offline
Sr. Member
I'm on YouTube! Search AKSoapy29
View Profile
WWW
What is Python (Beside a language) and how do I get started? I kind of want to do the same thing.
Logged
Find AKSoapy29 on:
Youtube
Website
Germany
Offline Offline
Newbie
View Profile
First you need to Install Python: http://www.python.org/download/
Then you have to understand the language (but this is not Necessaray, you learn with the Programms you read)
Maybe you need the Com port here is a little Programm:
Code:
import serial
COMPORT = 8
BAUDRATE = 115200
MASSAGE = "Testnachicht"
print "Initialisiere Comport %s mit einer Baudrate von %s" % (COMPORT, BAUDRATE)
ser = serial.Serial(COMPORT, BAUDRATE, timeout=0)
print "Comport Initialisiert"
print "Sende '%s'.." % (MASSAGE)
ser.write('5')
print "...gesendet"
Important is that in this Language no ; and { exist like in Java.
My finished E-Mail Programm that checks for "Start" and sends 1 over serial and "Stop" and sends 2
Code:
# -*- coding: cp1252 -*-
import sys, getpass, poplib, re
import serial
import time
# arduino connection
COMPORT = 8
BAUDRATE = 115200
# change according to your needs
POPHOST = "popmail.t-online.de"
POPUSER = "sebastian.frebel@t-online.de"
POPPASS = raw_input("Bitte gieb dein E-Mail Passwort ein:")
# the number of message body lines to retrieve
MAXLINES = 10
HEADERS = "@Arduino".split()
print "Erwartete Header: %s" % (HEADERS)
print "Max. Zeilen: %s" % (MAXLINES)
# headers you're actually interested in
rx_headers = re.compile('|'.join(HEADERS), re.IGNORECASE)
try:
    # Hauptmenüü
    while 1:
        # Space
        print
        print
        print 50 * "_"
        print
        print
        print
        key = raw_input("(w=wait for Massage, o=organize Mailbox, q=quit) What?")
        if key == 'w':
# Anfang warten
            # connect to POP3 and identify user
            pop = poplib.POP3(POPHOST)
            pop.user(POPUSER)
            if not POPPASS or POPPASS=='=':
                # if no password was supplied, ask for it
                POPPASS = getpass.getpass("Password for %s@%s:" % (POPUSER, POPHOST))
            # authenticate user
            pop.pass_(POPPASS)
            # get general information (msg_count, box_size)
            stat = pop.stat( )
            # print some information
            print "Logged in as %s@%s" % (POPUSER, POPHOST)
            print "Status: %d message(s), %d bytes" % stat
            print "Waiting for assignment for Arduino"
            # eigentliche Programm
            TIME = 10
            bye = 0
            count_del = 0
            while 1:
                n = 0
                for n in range(stat[0]):
                    msgnum = n + 1
                    # retrieve headers
                    response, lines, bytes = pop.top(msgnum, MAXLINES)
                    # suchen nach Begriff
                    #if lines.find('Stop') != -1:
                        #print "Stop in if gefunden!"
                    if 'Stop' in lines:
                        print "Stop Gefunden!!!"
                        print "Sende 1.."
                        ser.write('1')
                        print "...gesendet"
                    if 'Start' in lines:
                        print "Start Gefunden!!!"
                        print "Sende 2.."
                        ser.write('2')
                        print "...gesendet"
                    n = n + 1
                n = 0
                if "start" in response:
                    print "Loooooooooos!"
                pop.quit( )
                # Waits TIMEs
                time.sleep(TIME)
                pop.user(POPUSER)
                # authenticate user
                pop.pass_(POPPASS)
                stat = pop.stat( )
# Ende warten
        elif key == 'o':
# Anfang Organisation
            pop.user(POPUSER)
            # authenticate user
            pop.pass_(POPPASS)
            stat = pop.stat( )
            bye = 0
            count_del = 0
                msgnum = n+1
                # retrieve headers
                # print message info and headers you're interested in
                print "Message %d (%d bytes)" % (msgnum, bytes)
                print "-" * 30
                print "\n".join(filter(rx_headers.match, lines))
                print "-" * 30
                # input loop
                while 1:
                    k = raw_input("(d=delete, s=skip, v=view, q=quit) What?")
                    #k = k[:1].lower( )
                    if k == 'd':
                        # Mark message for deletion
                        k = raw_input("Delete message %d? (y/n)" % msgnum)
                        if k in "yY":
                            pop.dele(msgnum)
                            print "Message %d marked for deletion" % msgnum
                            count_del += 1
                            break
                    elif k == 's':
                        print "Message %d left on server" % msgnum
                        break
                    elif k == 'v':
                        print "-" * 30
                        print "\n".join(lines)
                        print "-" * 30
                    elif k == 'q':
                        bye = 1
                        break
                # done ...
                if bye:
                    print "Bye"
                    break
            # summary
            print "Deleting %d message(s) in mailbox %s@%s" % (
                count_del, POPUSER, POPHOST)
            # close operations and disconnect from server
            print "Closing POP3 session"
            pop.quit( )
# Ende Organisation
        elif key == 'q':
            quit()
        else:
            print "Falsche Eingabe. Bitte versuche es nocheinmal."
except poplib.error_proto, detail:
    # possible error
    print "POP3 Protocol Error:", detail
« Last Edit: May 17, 2011, 12:43:37 pm by Robohac » Logged
Germany
Offline Offline
Newbie
View Profile
I forgot: The structure is important so:
right:
Code:
while 1:
        # Space
        print
        print
        print 50 * "_"
wrong:
while 1:
# Space
print
print
print 50 * "_"
« Last Edit: May 17, 2011, 12:41:39 pm by Robohac » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
@robohac
Please modify your (excellent) postings, select the code and press the # button to tag it properly,
Thanks,
Rob
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Sr. Member
View Profile
With python and Arduino ! the LED trun on when a mail (gmail ) arrive !
http://arduino.cc/forum/index.php/topic,54332.0.html
In french sorry ^^
Logged
Mon Blog sur l'environnement Arduino ... Tutos fait par un débutant pour les débutants ^^
http://chicowebsite.free.fr/
Pages: 1 [2]   Go Up
Print
Jump to:
