Loading...
Pages: [1]   Go Down
Author Topic: Can't save data in Arduino EEPROM  (Read 883 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi.
Can't save data in my Arduino EEPROM. I've try with a MEGA 1280 and a Duemilanove: same results
I went back to basics (EEPROM READ - EEPROM WRITE)  and can't obtain results:
even with the example (loop write - read)
it seems work, but when i remove the write command, the result of my reading is 256 for every data.
Here is my code:
Code:
#include <EEPROM.h>
int a = 0;
int value;
int i;
for ( i = 0; i < 256; i++)     // 256  because it holds 1 byte only
   EEPROM.write(i, i);   // Write 0 in position 0, 1 in position 1 and so on
   delay(5);
   value = EEPROM.read(i);   //read position
  Serial.print(i);
  Serial.print("\t");
  Serial.print(value);
  delay(50);
// Result: serial monitor should appear : 0   0 / next line 1  1 ... /next line 256  256
I hope anyone can helpme !!!  smiley-cry
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
HI Gabo,
(right forum this time smiley-wink
The problem might be that EEPROM.write() uses two parameters and the value parameter should be a byte. - See http://www.arduino.cc/en/Reference/EEPROMWrite
You might cast the value like below.
Code:
#include <EEPROM.h>
int value;
for (int i = 0; i < 256; i++)     // 256  because it holds 1 byte only (BUT STILL IS AN INT!!)
   EEPROM.write(i, [color=red](byte)[/color] i);   // Write 0 in position 0, 1 in position 1 and so on
delay(100);
  Serial.print(i);
  Serial.print("\t ");
  Serial.println(value);
void loop() {}
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Look at the EEPROM::write() function. Notice, in particular, what the type of the 2nd argument is. Then, compare that to the types of the arguments that you provide.
If you were to call the function with the correct type of argument, you would get correct results.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Your sketch works fine for me on a Diecimila.  I upload the sketch, run it, see the expected output, comment out the write line, re-upload it, re-run it and see the same output.
Are you using something other then the IDE and USB port to upload your sketch?  Perhaps and Flash and EEPROM are being cleared as part of the upload.
« Last Edit: March 21, 2011, 01:30:26 pm by johnwasser » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
That's pretty remarkable.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm using the sparfun's AVR pocket programming...
I'll try using the USB.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
If that is the root of the problem, then part of the blame might be the example sketch used in the Arduino reference section for EEPROM:
http://arduino.cc/en/Reference/EEPROMWrite
Code:
Example
#include <EEPROM.h>
  for (int i = 0; i < 512; i++)
    EEPROM.write(i, i);
And I ran the OP's sketch and it seemed to work fine writing to eeprom, and later after commenting out the writting to eeprom, still held and printed valid data from the eeprom.
Lefty
« Last Edit: March 21, 2011, 02:45:27 pm by retrolefty » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I upload the sketch using the bootloader instead the Pocket programmer and it works fine.
then, the pocket programmer clears the IC and rewrites it????
The example works fine but it's incorrect.
Then I have to tear apart the value (integer)  in two bytes to save... and when I need to retrieve the value I need to call both bytes and "paste them" ???
How to do that ????
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Write 16 bit integer 'value' into i and i+1:
  EEPROM.write(i, value>>smiley-cool;   // Write high byte
  EEPROM.write(i+1, value);  // Write low byte
Read 16-bit integer 'value' from i and i+1:
value = (EEPROM.read(i) << smiley-cool | EEPROM.read(i+1);
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
http://arduino.cc/en/Reference/HighByte
http://arduino.cc/en/Reference/LowByte
Logged
Pages: [1]   Go Up
Print
Jump to:
