Topic: Boards Manager - Error Downloading http://downloads.arduino.cc/packages/pack... (Read 12786 times) previous topic - next topic
parkolay
There is also the very real possibility that you need to configure the Arduino IDE to use your proxy (as I found to be the case for me).
Under the Arduino IDE preferences menu, on the Network tab, I needed to add the "Automatic proxy configuration URL" that I found in LAN settings on my computer, (if using chrome, you can drill down to
 this under settings, advanced settings, open proxy settings and click on the "LAN settings" button (for Crome Version 71.0.3578.98 (Official Build) (64-bit)).
Alternatively you can also go to control panel, Internet options, and the connections tab will have the LAN setting button (if using WIN8)).
aerssefr
Dear Parkolay,
Thanks a lot.  After 3 evenings of searching, your suggestion is also the solution in my case.
Indeed I needed to add the "Automatic proxy configuration URL"
acharbeck
hello,
i have tried with several ways. but it is not working.
is there any solution for this error
Error downloading https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json
