Author Topic: Noise from motor trashing IC  (Read 360 times)
I am experiencing noise and voltage drops when a pager motor is turned on and off via a PWM signal from the IC.  After about 2 days of continuous operation it is frying the IC.
I am looking for guidance on how to isolate the IC from the motor so that the voltage fluctuations that occur when the motor starts & stops don't affect the IC.
I've attached 2 images:
1) breadboard view
2) schematic
The sketch on the IC is basically an analog version of the Blink example.
The minimum requirements for this project are:
1) It must run off of a 3V coin cell battery, and no more than two 3V coin cell batteries
2) It must use an IC, I am using an ATTiny85
3) The motor must be no bigger than a Pager motor
Ideally, I would like to run with two 3V coin cell batteries; one for the IC to pump the transistor & one to drive the motor via transistor.
If I run this sketch with an LED instead of a motor it will last for a little over one week.
Any suggestions on how to isolate the motor from the IC?  Or, "Well, there's your problem...."
Here is the BOM on the breadboard:
D1            Rectifier Diode (1N4001)
IC1           ATTiny85
M1            DC Motor (Pager Motor)
Q1            NPN-Transistor (PN2222A)
R1            10k Resistor
VCC1          3V Coin Cell
Thanks,
-Mike
Phoenix, Arizona USA
Where's the beer?
Start here: http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
The short of it - you need an isolation capacitor across the motor leads, and a capacitor (as close to the microcontroller as possible) across the positive rail to the ground rail. That, or use an optocoupler. Or a relay.
Read parts 2-4 as well on the site. Mike is long known around here as "Grumpy Mike" - you might've run into him before...
« Last Edit: March 21, 2011, 11:05:49 pm by cr0sh » Logged
You need a _minimum_ of a 100nF ceramic decoupling capacitor and something like 470uF -- 3300uF electrolytic as well to handle motor transients/spikes.  All digital electronic circuits need proper decoupling - and if a motor's involved its good policy to use entirely separate supplies if possible because of the inductive spikes and crow-barring of the motor supply.
Thanks cr0sh & MarkT.
I'll take all of this in and give it another shot.
Thanks,
-Mike
