Offline
Newbie
« on: March 22, 2011, 01:56:21 am » |
Hello,
trying to program an ATtiny2313 with a metaboard-programmer (arduino clone) and the Arduino-IDE runnig avr-developers special core, I have a problem with the -D option in AVRDude, that is the default (disable chip erase). A naked chip is programmed with no problems, but the second try ends up in a verify-error. I had to do a chip erase "manually" (-e) and it worked.
Is there a method to overwrite the -D option from the Arduino-IDE? I dind´t find it in the AVRDudeconfig or Arduino-Preference.
Thanks for Help Themroc
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #1 on: March 22, 2011, 02:07:13 am » |
I have a problem with the -D option in AVRDude, that is the default (disable chip erase) Disable chip erase is the default? Doesn't seem to be for my version (5.10). Which version are you using?
Logged
Offline
Newbie
« Reply #2 on: March 22, 2011, 02:14:02 am » |
I meant the Arduino-IDE calling AVRDude default. I´m using 022. AVR-Dude is ok:)
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #3 on: March 22, 2011, 02:28:49 am » |
The command line when I upload an empty Sketch... C:\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cavrispv2 -P\\.\COM8 -Uflash:w:C:\Users\CODEB~1.001\AppData\Local\Temp\build1468340934531411719.tmp\sketch_mar22b.cpp.hex:i Broken into separate lines... C:\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cavrispv2 -P\\.\COM8 -Uflash:w:C:\Users\CODEB~1.001\AppData\Local\Temp\build1468340934531411719.tmp\sketch_mar22b.cpp.hex:i
There is no dash-D. I suspect the problem is something else.
Logged
Offline
Newbie
« Reply #4 on: March 22, 2011, 04:02:27 am » |
Oh sorry my version contains the -D option and I can´t get it away:)
D:\arduino-0022\hardware/tools/avr/bin/avrdude -CD:\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny2313 -cusbasp -P\\.\COM12 -b19200 -D -Uflash:w:C:\DOKUME~1\Me\LOKALE~1\Temp\build1303 597068202028020.tmp\BlinkWithoutDelay.cpp.hex:i
thanks themroc
Logged
Offline
Newbie
« Reply #5 on: March 22, 2011, 05:17:34 am » |
I tested it with the same command ommitting the -D and it worked. But it´s boring to copy the command from the Arduino-IDE and deleting -D.
Any idea, how to set (or to find) the right preference file?
T
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #6 on: March 22, 2011, 04:38:18 pm » |
Do you have an "upload.using" entry in "boards.txt" for the ATtiny2313 section? It should be something like this...
myboardname.upload.using=myprogrammer
Logged
Offline
Newbie
« Reply #7 on: March 22, 2011, 05:32:10 pm » |
NO I didn´t, but the other boards don´t have this option. I only specified the upload.protocol=usbasp. The Problem is, that the upload works once. It is definitly the -D option. Iwrote a batchfile to erase the chip before.
Regards T
Logged
Offline
Newbie
« Reply #8 on: March 22, 2011, 05:33:25 pm » |
Ok Iwould like to know what this using does.
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #9 on: March 23, 2011, 01:41:18 am » |
When a section in "boards.txt" does not have an "upload.using" entry, the Arduino IDE performs a "bootloader upload". For you, that means the dash-D option is added when AVRDUDE is run. When you want to upload using an ICSP (in your case the "metaboard-programmer") you have to either add an entry to "programmers.txt" or select a close match. As far as I can tell, this is what you should add "programmers.txt"... metaboard.name=USBasp metaboard.protocol=usbasp You then need to update "boards.txt" so that uploading to your board is performed through the "metaboard" programmer. Something like this should work... attiny2313at8.name=ATtiny2313 @ 8 MHz attiny2313at8.upload.using=metaboard attiny2313at8.upload.maximum_size=2048 attiny2313at8.bootloader.low_fuses=0xE4 attiny2313at8.bootloader.high_fuses=0x9F attiny2313at8.bootloader.extended_fuses=0xFF attiny2313at8.bootloader.path=empty attiny2313at8.bootloader.file=empty2313at8.hex attiny2313at8.bootloader.unlock_bits=0x3F attiny2313at8.bootloader.lock_bits=0x3F attiny2313at8.build.mcu=attiny2313 attiny2313at8.build.f_cpu=8000000L attiny2313at8.build.core=CoreSubdirectoryGoesHere
Logged
Offline
Newbie
« Reply #10 on: March 23, 2011, 06:19:16 am » |
Thanks for explanation. I ´will try this. Did you work with the special cores from AVR-developers? With the attiny2313 I got it working, but not with an Atmega48 or 8. Uploading the bootloader works with the Atmega8, sketches are uploaded correctly, but don´t work.
T
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #11 on: March 23, 2011, 11:07:15 am » |
Did you work with the special cores from AVR-developers? No, I haven't.
Logged
Offline
Newbie
« Reply #12 on: March 23, 2011, 12:36:07 pm » |
Thanks a lot coding badly. With your "using" modification it worked fine. The terrible -D option disappeared.  I used the following code: programmers.txt usbasp.name=USBasp usbasp.communication=usb usbasp.protocol=usbasp boards.txt ... atmega8.name=Arduino ATmega8 atmega8.upload.using=usbasp atmega8.upload.protocol=usbasp #maybe this is double? ... The avr-developers files support many of the other avrs, so that you can programm it with the Arduino IDE. Although the blink-sketch uses nearly half the flash of a Tiny2313:( Unfortunately Atmega48 doesn´t work. Maybe it is the fuses-section. T
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #13 on: March 23, 2011, 12:44:23 pm » |
For the ATtiny2313, give this core a try... http://code.google.com/p/arduino-tiny/
Logged
Offline
Newbie
« Reply #14 on: March 24, 2011, 05:58:45 am » |
Oh thanks. Does this core generate an optimized version for the tinys (to fit in the small flashes). The documentation in the boards.txt is really good (especially the fuse-settings). What about the "empty" bootloader specification? Is this only to set the right fuses, not to upload a bootloader?
T
Logged
