Topic: Arduino AVRDude -D option (Read 6601 times) previous topic - next topic
Coding Badly
Does this core generate an optimized version for the tinys (to fit in the small flashes).
That's the goal.
Quote
The documentation in the boards.txt is really good (especially the fuse-settings).
Thanks!
Quote
What about the "empty" bootloader specification? Is this only to set the right fuses, not to upload a bootloader?
Exactly.  The "empty" bootloaders serve two purposes: a convenient way to change the fuses from the Arduion IDE; clear out the current Sketch so the hardware can be safely changed.
themroc
Fine, you are the programmer? Your core is really better the code is smaller. Now I unaderstand a bit more AVR-language.
Thanks.
T
Coding Badly
Quote
Yup.  Other folks are certainly welcome to participate!
Quote
Excellent!  For the ATtiny85 processor, the next update will be even better.  My programs have been 3.5% to 5% smaller with it.  In addition, for the digital functions, if the parameters are compile-time constants, they reduce to single machine instruction.  The code is a variation of the digital*Fast functions.
There are some options in the "core_build_options.h" that can be used to shave a tiny bit off the program size.
For the ATtiny2313, if you're doing write-only serial, using Tiny Debug Serial instead of HardwareSerial reduces the program size.
Quote
Glad to hear it!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
