Topic: Estimating sketch size (Read 989 times) previous topic - next topic
Hi, is there any way to estimate the size of a program before writing it?
PaulS
Quote
Only in the vaguest possible terms, like small, humongous, and "won't fit".
Now, with some idea what hardware you are interfacing with, and the requirements for the application, then the estimate can be made a bit more accurate.
WillR
If you are working with large arrays and so on -- yes -- to that extent.
Otherwise you have to do what I do -- I compile the code before I write it. That way I don't have to guess.
Just another Hacker
robtillaart
Quote
1) experience^2 is needed
2) if you use libraries with known size helps a lot
3) usage of floating point adds approx 3-4K to your code. (is also a lib)
4) the complexity of the algorithms needed
5) the amount of storage (including temporary) needed
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
