Loading...
Pages: [1]   Go Down
Author Topic: Dynamic matrix  (Read 829 times)
Greece
Offline Offline
Newbie
View Profile
I have written below code for dynamic matrix, and it has got an error compiling
C:\Users\kostas\AppData\Local\Temp\build6344196874205377199.tmp/dynamic_matrix.cpp:83: undefined reference to `operator new[](unsigned int)'
C:\Users\kostas\AppData\Local\Temp\build6344196874205377199.tmp/dynamic_matrix.cpp:86: undefined reference to `operator new[](unsigned int)'
 and I don’t understand, that is the wrong?
Code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 6, 7);
int **matrix;
int m;  //col
int n;  //row
/////////////////////////DILOSI METAVLITON GIA TO PLIKTROLOGIO
int analogInputPin=0;
int totalOutputDigit=9;
int KeyForEnder='D';
int keyForClear='C';
int rowToPrint=0;
int columnToPrint=0;
int keyboardMode='mod0';
int IncomingString;
///////////////////////////DILOSI METAVLITON GIA TO PLIKTROLOGIO
void printmatrix(int **matrix, int m, int n);
void readmatrix(int **matrix, int m,int n);
  Serial.begin(1200);
  lcd.begin(6,2);
  rowToPrint=15;
  columnToPrint=1;
  lcd.print("row");
   n=getPressString(IncomingString,analogInputPin,KeyForEnder,keyForClear,rowToPrint,columnToPrint,keyboardMode);
  Serial.print("number row:");
  Serial.print(n);
  lcd.clear();
  lcd.print("collumn");
   m=getPressString(IncomingString,analogInputPin,KeyForEnder,keyForClear,rowToPrint,columnToPrint,keyboardMode);
  Serial.print("number col:");
  Serial.print(m);
  lcd.clear();
  matrix= new int*[n];
  for(int i=0; i<n; i++)
    matrix[i]=new int[m];
  readmatrix(matrix, m, n);
  printmatrix(matrix, m, n);
halt:
  goto halt;
  int i,j;
  int rowToPrint=15;
  int columnToPrint=1;
  for(i=0; i<=n; i++)
    for(j=0; j<=m; j++)
      lcd.print("stoixeio ");
      lcd.print(i);
      lcd.print(j);
      matrix[i][j]=random(200);
      Serial.print(matrix[i][j]);
  int i,j;
  for(i=0; i<=n; i++)
    for(j=0; j<=m; j++)
    Serial.println(" ");
The function getPressString read the keyboard (4 row, 4 column, 16 button)
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
There is no "new" operator in Arduino.
Quote
halt:
  goto halt;
Run for the hills!
« Last Edit: March 22, 2011, 04:31:41 am by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Greece
Offline Offline
Newbie
View Profile
How to make a dynamic matrix in the arduino IDE?
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
malloc?
Logged
Greece
Offline Offline
Newbie
View Profile
Can you give me an example please?
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Code:
int* vector = (int*)malloc(sizeof (int) * vect_size);
Logged
Greece
Offline Offline
Newbie
View Profile
Last question, I hope….
I want to create 2D array, that’s wrong with this code?
Code:
int x,y;
 int* vector = (int*)malloc(sizeof (int) * x);
 for(int i=0;i<2; i++)
    int*  vector[i]=(int*)malloc(sizeof (int) *y);
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
A vector is a one-dimensional array.
Logged
Greece
Offline Offline
Newbie
View Profile
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Reply #5.
Your code in reply #6 simply creates vectors, and when the inner loop finishes, one will no longer exist, and you've got no way of freeing it.
« Last Edit: March 22, 2011, 05:45:15 am by AWOL » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I want to create 2D array, what’s wrong with this code?
Code:
int x,y;
    int*  vector=(int*)malloc(sizeof (int) *y);
You have not defined values for x and y, so they will contain garbage. You are then defining an array of garbage size.
You are declaring a local variable, vector, in the for loop. It will go out of scope when the loop ends. The variable is an array of pointers to ints that you are trying to value with a single pointer to int, of garbage size.
Do you realize how much (actually, how little) SRAM the Arduino has for arrays?
If you correctly define vector, which, as AWOL points out, is a lousy name for a 2D array, you will need to pass the dimensions to any function that uses that array, and to free the memory used by the array when you are done with it.
Logged
Pages: [1]   Go Up
Print
Jump to:
