Loading...
Pages: [1]   Go Down
Author Topic: HP LaserJet Control/Display Panel  (Read 2267 times)
Offline Offline
Newbie
View Profile
HP LaserJet control panel hooked up to an Arduino:
This has been done before here: http://hackaday.com/2009/07/20/touchpad-and-vfd-hacking/ but the links to the details are dead so there seemed to be a good excuse to do it again. I haven't seen anyone demo the buttons and LEDs before either. The board isn't really very practical to reuse but it was fun to mess around with. I believe the M66004 VFD driver IC is also used in some Hi-Fi equipment also.
Library, sketch and other details are available here: http://arduino.cc/playground/Main/M66004Vfd
« Last Edit: March 22, 2011, 07:51:58 pm by TitaniumStudios » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
YES!  I have had this VFD board sitting in my drawer for about a year now, itching to use it in a project.
Thank you very much for documenting this, extremely helpful!  Thank you even more for the PM to inform me of your post!
*Tips hat*
:: Update ::
Got a chance to hook mine up and try it, and it works!  Mine only had 9 pins in a single row though, so I had to determine the correct connections for mine with a bit of trial and error (along with some help from a multi-meter)
Here is the pin-out for my board:
Pin 1 - Ground
Pin 2 - Ground
Pin 3 - LED/Button dataReadPin
Pin 4 - LED/Button latchPin
Pin 5 - VFD chipSelectPin
Pin 6 - clockPin (for both)
Pin 7 - dataWritePin (for both)
Pin 8 - +5 Volts
Pin 9 - +5 Volts
« Last Edit: March 25, 2011, 09:59:19 pm by gigawatts » Logged
Offline Offline
Newbie
View Profile
Not sure if you saw this page: http://arduino.cc/playground/Main/HpLaserJetControlDemo but I had a guess for the 9 pin pinout on it. Thanks for confirming it.
Do you have any plans for the board?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Heh, no, I didn't see that page. Oh well, glad I could help.
I'll probably end up implementing it in the thermostat I was working on, instead of the LCD I was going to use, as this already had buttons and status LED's built in.
Thanks again!
Logged
Pages: [1]   Go Up
Print
Jump to:
