Loading...
Pages: [1]   Go Down
Author Topic: Arduino UNO and SCP1000  (Read 1581 times)
Offline Offline
Newbie
View Profile
Hello,
I am an Atmospheric Science student at the University of Nevada in Reno, Nevada. Our professor purchased the Arduino boards and a set of SCP1000 chips equipped with the barometric pressure/temperature sensor.
We successfully wired the chip to the Arduino board and are attempting to run the "BarometricPressureSensor" example sketch for use in a project. After successfully uploading the sketch to the Arduino board, we are having trouble interpreting the results:
100000   10000000
Pressure [Pa]=3687
100001   10000100
Temp[C]=26.6511111   1111100
100000   10000000
Pressure [Pa]=3690
100001   10000100
Temp[C]=26.5511111   1111100
100000   10000000
Pressure [Pa]=3677
100001   10000100
Temp[C]=26.6011111   1111100
100000   10000000
Pressure [Pa]=3663
The pressure, in Pascals, in Reno, Nevada should be about 850 millibars, or approximately 85 000 Pascals.
At first, we thought the sensor onboard the SCP1000 might be faulty, so we tried another sensor on another Arduino board and are getting the same values.
If you could provide some insight into the SCP1000 and this issue, it would be greatly appreciated.
Thank you,
Nic Beres
Logged
Georgina Ontario
Offline Offline
Sr. Member
Arduino rocks
View Profile
How do you correct for altitude?
Get yourself a BMP085
http://www.sparkfun.com/products/9603
Get the library here..
http://code.google.com/p/bmp085driver/downloads/list
It should work a lot better.
Logged
Just another Hacker
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Please share the code used, maybe its in the SW.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
My SCP1000 works fine (incredibly sensitive, can 'measure' altitude to 20cm or something like that) - you need to show us the code to work out what's going wrong.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Just a quick thought - you have read all 19 bits of pressure? address 0x1F reads the top 3 bits, 0x20 the bottom 16 bits.
Logged
Georgina Ontario
Offline Offline
Sr. Member
Arduino rocks
View Profile
Mark:
Is it "better" that the BMP085?
Could I use it to detect low frequency (Seconds per cycle as opposed to CPS) pressure waves?
If you are using a good library maybe you can point it out. I am always looking for ways to do things better...
Logged
Just another Hacker
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Looks like they have similar specs but the Bosch one is a lot quicker?   Confused for a while with the Bosch datasheet using hPa as the unit of pressure - what?  0.01hPa = 1Pa (crazy Bosch engineers!)  The SCP100 takes 0.75s for high-accuracy conversion I think, BMP085 is 25.5ms.  For your bandwidth it might be better to have higher speed device or you'll be hitting the Shannon limit.
Logged
Offline Offline
Newbie
View Profile
There is a problem with the sample sketch in that the binary shifts do not work in some places. Replace wherever it says "<< n" where n is an integer with *(2^n) where you have precalculated 2 to the n.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Sure its not a failure to declare types big enough?  I've not seen << misbehaving.
Logged
Offline Offline
Newbie
View Profile
Yes, it's something like that. I can't remember the modifications I made, but the << 16 for the pressure definitely didn't work. I think I ended up using a 'long' for pressure. Try that. I'm also in the middle of writing a library for the SCP1000, so if you want I can make it available to you when finished.
Logged
Pages: [1]   Go Up
Print
Jump to:
