Topic: Issue loading sketches to Sanguino. IDE 0022, Ubuntu 10.10 [solved] (Read 2160 times) previous topic - next topic
Mr._Swarf
Mar 23, 2011, 04:11 am Last Edit: Mar 23, 2011, 07:59 pm by Mr. Swarf Reason: 1
I finished building a Sanguino last night. I've downloaded the files from the Sanguino project and installed as directed.
I can upload the bootloader to the board on the linux machine via the IDE and my USBasp ISP programmer. However when I attempt to upload a 'blink' sketch via the IDE to the Sanguino I get these errors:
In file included from Blink.cpp:8:
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/WProgram.h:4:20: error: stdlib.h: No such file or directory
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/WProgram.h:5:20: error: string.h: No such file or directory
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/WProgram.h:6:18: error: math.h: No such file or directory
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/WProgram.h:8:27: error: avr/interrupt.h: No such file or directory
In file included from /usr/share/arduino-0022/hardware/Sanguino/cores/arduino/WProgram.h:10,
                from Blink.cpp:8:
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:28:20: error: avr/io.h: No such file or directory
In file included from /usr/share/arduino-0022/hardware/Sanguino/cores/arduino/WProgram.h:13,
                from Blink.cpp:8:
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/HardwareSerial.h:23:22: error: inttypes.h: No such file or directory
                from Blink.cpp:8:
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:97: error: 'uint8_t' does not name a type
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:98: error: 'uint8_t' does not name a type
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:102: error: variable or field 'pinMode' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:102: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:103: error: variable or field 'digitalWrite' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:103: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:104: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:105: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:106: error: variable or field 'analogReference' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:106: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:107: error: variable or field 'analogWrite' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:107: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:107: error: expected primary-expression before 'int'
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:109: error: variable or field 'beginSerial' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:109: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:109: error: expected primary-expression before 'long'
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:110: error: variable or field 'serialWrite' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:110: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:110: error: expected primary-expression before 'unsigned'
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:111: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:112: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:113: error: variable or field 'serialFlush' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:113: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:119: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:119: error: expected primary-expression before 'unsigned'
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:119: error: initializer expression list treated as compound expression
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:121: error: variable or field 'shiftOut' declared void
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:121: error: 'uint8_t' was not declared in this scope
/usr/share/arduino-0022/hardware/Sanguino/cores/arduino/wiring.h:121: error: 'byte' was not declared in this scope
What's really screwy is the Sanguino uploads work just fine via the IDE on my Mac with the 0022 IDE installed.... I have the blink sketch running via the upload from my Mac.
I'm using the same files from the Sanguino web site. I've checked and it does not look like a permissions issue on the Linux system.
Any ideas?
Thank you in advance.
M.S.
Coding Badly
Are you able to build (Verify) a Sketch for any board on the Linux computer?
Mr._Swarf
Crap. I have not tried that since reloading the software. The only hacking I've done is on the new Sanguino I built. I'll give it a spin tomorrow when I get into my workroom/office again.
M.S.
Mr._Swarf
Well foo. It won't build for other boards either....
I've reinstalled the software from a freshly downloaded package. Still broken.
Ubuntu 10.01 AMD64 with the 64 bit Linux package.
This was working previously. I had to rebuild my system over the weekend due to a failing hard disk.
M.S.
Mr._Swarf
This is now working. I thought about what I had done differently on my previous install.
Via apt-get I had to install the Arduino (0018) software from the Ubuntu repository. It appears the install also grabbed some dependencies needed. Once installed the 0022 software just works.
Bleah.
M.S.
