Topic: Arduino Mega 2560 and M0 (Read 462 times) previous topic - next topic
Kranvonkyln
Hello,
I'm trying to connect Arduino Mega 2560 and Arduino M0 thru SPI. I wrote some code but it doesn't work.
Master:
#include <SPI.h>
#include "pins_arduino.h"
pinMode(SS, OUTPUT);
digitalWrite(SS, HIGH);
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV8);
void loop(void)
  char c;
  digitalWrite(SS, LOW);
  for (const char *p="Hello\n"; c = *p; p++){
  SPI.transfer(c);
  delay (500);
Slave:
#include <SPI.h>
char buf[100];
volatile byte pos;
volatile boolean process_it;
 Serial.println("SPI test");
 pinMode(MISO, OUTPUT);
 //digitalWrite(MISO, LOW);
 SPCR |= _BV(SPE);
 pos = 0;
 process_it = true;
 SPI.attachInterrupt();
ISR (SPI_STC_vect){
  byte c = SPDR;
  if(pos < sizeof buf)
     buf[pos++] = c;
    if(c =='y'){
    process_it = true;
void loop (void)
 if(process_it){
      Serial.println(buf);
      Serial.println("X");
      pos=0;
      process_it = false;
It looks like ISR (SPI_STC_vect) wouldn't work. c is allways 0 and buf ist empty.
pylon
Mega2560 and M0 have different voltage levels. Do you use level converter for all SPI signals?
If you connected them directly check the pins on the M0 for damage as the 5V of the Mega2560 are over specs.
aapatil
  SPI.transfer(c);
  delay (500);
Looking at this piece of code, you pull SS low, transfer code, pull SS high, transfer code again, pull SS high, etc. You never pull SS low again, so you wouldn't be able to transfer anything.
Kranvonkyln
What do you mean with different voltage levels? No I'm not using level converter.
Yes, my bad. I took SS high out of for loop but it didn't help.
pylon
Quote
The Mega2560 runs on 5V so do all of it's IO signals. The M0 runs on 3V3 and so do all it's IO signals. If you put 5V to one of the pins of the M0 you might fry it.
BTW: we haven't seen your wiring diagram yet. Did you connect the GNDs?
Kranvonkyln
Yes i connected the GND, I'm posting my wiring. That's M0 and Mega 2560 in my program there is no M0.
About voltage level, M0 works fine so I think i didn't fry it. Can the different voltage level be the issue ?
Juraj
#6
Aug 11, 2018, 05:54 pm Last Edit: Aug 11, 2018, 05:59 pm by Juraj
M0 doesn't have SPI on 11, 12, 13.
only on the fake ICSP header and only master
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
Kranvonkyln
So what does it mean? M0 can't comunicate through SPI?
Juraj
you can connect SPI slaves to the ICSP header .
for slave it is more work and a level deeper
https://forums.adafruit.com/viewtopic.php?f=25&t=94366
Kranvonkyln
I want to use M0 as a Master and Mega 2560 as a slave.
Juraj
#10
Aug 12, 2018, 06:37 am Last Edit: Aug 12, 2018, 06:38 am by Juraj
I like this picture by Nick Gamon. The M0 hasn't the SPI function on 11, 12, 13 but the ISCP header is the same, including 5 V VCC
Kranvonkyln
I feel so stupid, thank you very much, I've used wrong Pins. Now when I'm using ICSP it works. Can I ask one more question? Over SPI go 8Bit how can I transfer 12 Bit?
pylon
Quote
By transferring 16 bit (2 bytes) and forgetting 4 bits of that transfer.
