Topic: Arduino-Due and 2 SPI slaves (Read 354 times) previous topic - next topic
nagu3112
I am using Arduino-Due with I2C & UART peripherals.
I like to interface two more slave devices using SPI.
I am planning to use one SPI port and select the slaves with different chip select pins.
For 2.5 Milliseconds, I will read 12 bytes of data from Slave1 and then immediately will write the same to Slave2 .
Does SPI library supports above / Is it possible?
D74-MISO
D75-MOSI
D76-MSCK
D87 - CS1 for Slave1 select
D52 - CS2 for Slave2 select
david_prentice
Yes,   that is why city buses have lots of seats and big doors.
You have one driver (Master) and many passengers (Slaves)
The Master can only talk to one Slave at a time.
David.
nagu3112
