Topic: DS18S20 and DS18B20 are both 5 degrees off (Read 11198 times) previous topic - next topic
Raegin
I am trying to get proper temperature readings for both of these one-wire sensors (not at the same time). They are connected in parasite mode as described on http://www.arduino.cc/playground/Learning/OneWire. Along with the sketch on that page.
The problem is that both the DS18S20 and DS18B20 are about 5 degrees too high when compared to a calibrated digital thermometer with probe. To check this I have put the one-wire sensors along with the thermometer probe in ice water. The probe gave me a reading of 0-1 while both one-wire sensors gave a reading of 3-4 degrees. All sensors were in ice water for several minutes.
When everything is at room temperature the probe gives me a reading of 19 while the one-wire sensors give a reading of 23.xx. I have tried two different DS18S20 sensors and two different DS18B20 but no joy for me.
I have absolutely no idea why I'm reading the temperature with such an offset. Does anyone know what could cause this?
WillR
Why not supply power and retest before this goes any further. I have several digital thermometers that do track well and the DS18B20 is one of them.
I do supply regular power.
Raegin
I've tried the normal power mode as well, forgot to mention that. With both modes I get the same reading. I know that the DS18B20 and DS18S20 are suppose to be calibrated already and I trust that mine are too. My guess is that the error comes from somewhere else but I don't understand where.
I've tried changing the cables but that doesn't change anything.
MarkT
With normal power you have decoupling on the chip?  It does sound like they are out of spec (are they genuine parts or clones?  Were they soldered for too long causing thermal stress perhaps?)
(Also double check your caclulations - print the raw temperature value and do the conversion by hand to check)
WillR
Maybe there should be "post  the code" reminder?
And a good question is -- are you using the Dallas One-Wire code found here or where is it from?
The Dallas Library from here works...
http://milesburton.com/index.php/Arduino#Libraries
Raegin
I don't think I understand your first quetion about decoupling on the chip.
The parts I'm using are genuine dallas chips. I have the same issue with multiple chips, two were ordered last week and the other two were ordered a year or two ago. The chips are never soldered and were stored in anti-static bags.
I've tried several different codes, as I mentioned in the first post I've used the code found on the arduino playground. As well as the dallas library. They all give me the same readings. I even tried different wires and different values of pull-up resistors but no luck so far.
robtillaart
You have tried different DS18B20's.
Did you also test different Arduino boards? Or other processor board?
Rob Tillaart
WillR
Decoupling -- capacitors on the POWER line only. NOT using parasitic power.
Maybe you got a bad run... all I can think of at the moment.
paasselin
I am having the same problem!
I have two different sensors, both from Sparkfun (legit).
Everything is wired up correctly and the temperature is 5 degrees too high.
Emailed them about whether the batch had been tested.
wildbill
I have the same issue, I have a pair that both read a little high. Never been that bothered by it - they're just reporting temperature in the house to a web server. Now I'm intrigued though. This:
Is good advice I'll follow this evening.
paasselin
I know why XD !
The sensor was too close to the arduino.
When I keep them apart ( sensor and board), the temperature is good.
As soon as I take it close to the arduino the temperature shoots up!
I do not know why this happens but it's clear that it does influence my results.
fredericaltorres
I would like to report I see the same problem.
I tested with code that use the OnWrite library only and code that use OnWire and the DallasTemperature library and the problem is the same the temperature is 5 degree Celsius off
Cactusface
Hi All,
            For what it's worth I have used the DS18b20 lots of times, without any problems.
I have just checked the one on my seed propagator with the thermocopule on my DMM and its within 0.42 of a degree. Perhaps check the maths, also how many bits are you reading??
Regards
Mel.
Open your mind! But not too far, your brains might fall out.
Also like Photography, model building and my 300+ Cacti and Succs.
marcschneider
has this problem been solved? I'm having the exact same issue as the OP.
masmas10
I'm running in to the same problem. Problem started when running it on a ESP8266 stand alone. I was thinking maybe it is due to programming errors. So lets check it on my Arduino, but here  i get the same results. I have tested two DS18B20 sensors, and both on Arduino as on NODEMCU i get a reading which is 5 degrees to high. On the arduino i used to sketch the following sketch:
// This Arduino sketch reads DS18B20 "1-Wire" digital
// temperature sensors.
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress insideThermometer = { 0x28, 0xFF, 0xBB, 0xC9, 0x61, 0x15, 0x03, 0x22 };
DeviceAddress outsideThermometer = { 0x28, 0xFF, 0xE4, 0xC9, 0x61, 0x15, 0x03, 0xD8 };
DeviceAddress dogHouseThermometer = { 0x28, 0x59, 0xBE, 0xDF, 0x02, 0x00, 0x00, 0x9F };
void setup(void)
  // start serial port
  // Start up the library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(insideThermometer, 10);
//  sensors.setResolution(outsideThermometer, 10);
// sensors.setResolution(dogHouseThermometer, 10);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00) {
    Serial.print("Error getting temperature");
    Serial.print("C: ");
    Serial.print(tempC);
    Serial.print(" F: ");
    Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
  delay(30000);
  Serial.print("Getting temperatures...\n\r");
  sensors.requestTemperatures();
  Serial.print("Inside temperature is: ");
  printTemperature(insideThermometer);
  Serial.print("\n\r");
 // Serial.print("Outside temperature is: ");
////  printTemperature(outsideThermometer);
//  Serial.print("\n\r");
//  Serial.print("Dog House temperature is: ");
//  printTemperature(dogHouseThermometer);
//  Serial.print("\n\r\n\r");
wired according this setup:
Was wondering if anyone had already found the problem?
