Topic: Several getKey() (Read 2598 times) previous topic - next topic
meowcat
Hi..
I have problem for the keypad.getKey(). Here are the program.
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char answer;
int correct;
int wrong;
long i;
long j;
  //lcd.begin(16,2);
  //lcd.clear();
  //Serial.print(254, BYTE);
  //delay(100);
  Serial.println("Welcome to MATH GAME!!!");  // Initial dispaly
  Serial.println("Press * to start");         // Message on lcd
  //delay(2000);
  char key = keypad.getKey();
  if (key != NO_KEY)
    switch (key)
      case '*':
            Serial.println("[1] Addition");
            Serial.println("[2] Subtraction");
            Serial.println("[3] Exit");
            Serial.println("Choose");
            break;
      default:
          Serial.println("Please Press *");
            if (key != NO_KEY)
              switch (key)
                  case '1':
                    //Serial.println("ONE");
                    Addition();
                    break;
                  case '2':
                    Serial.println("Subtraction");
                    break;
                  default:
                    Serial.println("Nothing");
void Addition()
  i = random(10);
  j = random(10);
  if ((i<9) && (j<9))
      Serial.print(i);
      Serial.print("+");
      Serial.print(j);
      Serial.print("=");
      answer=i+j;
      if (key != NO_KEY)
        if (key == answer)
          Serial.println("CORRECT");
          Serial.println("WRONG");
  //Serial.println(answer);
The problem is for the "Press * to start", when I press *, the output is
[1] Addition
[2] Subtraction
[3] Exit
Choose
Then I choose 1, the output is Please Press *. I press 1 for three times..only the third one, the output is correct (0+2)
Please Press *
Please Press *
0+2
Then when I entered the answer, 2, the output is Subtraction. What I want is the output should be "CORRECT".
Actually I do not know how this program works and why this happen?..
Nick Gammon
Don't do two getKeys. The program doesn't wait you know, so unless you hit the second key within about 1 millisecond of the first (and the debounce would stop that anyway) then you won't get into the second switch statement. You want something like:
  switch (key)
  case '*':
    break;
  case '1':
    Addition();
    break;
  case '2':
    break;
  }  // end of switch
}  // end of loop
Don't put a default in. The default case will be no keypress.
And you need to revamp how you to the addition test. For example, what if you randomly generate 8 and 6? The answer is 14, and you can't get that back with a single kepress.
More info:
meowcat
So, I cant have answer with two digits..
But, in Addition(), how can I capture the key press by user, is it correct to use if (key == answer)?
Nick Gammon
No. One is a binary number, one is an ASCII string. Put it this way, if the question was 2 + 3, then the answer is 5. But you are testing for "5" from the keypad.  That is really 0x35 rather than 0x05.
More info:
meowcat
I have another question.. Can I have keypad.getKey() in if statement or switch?
Nick Gammon
Absolutely. Why not test it and see? However this should work:
  switch (keypad.getKey())
  case '*':
// nom nom nom
More info:
meowcat
#6
Mar 28, 2011, 10:42 am Last Edit: Mar 30, 2011, 03:59 am by meowcat Reason: 1
this is work..
 case '*':
// nom nom nom
but for the next switch, when I press 4 or other key, nothing happen..so I assume that this getKey() not working in switch..
     if (key != NO_KEY)
       switch (key)
         case '1':
             i = random(4);
             j = random(5);
             if ((i<=1 && j<=5) || (i<=4 && j<=1))
               lcd.setCursor(0,1);
               lcd.print("You Choose Add");
               delay(2000);
               lcd.clear();
               lcd.setCursor(1,0);
               lcd.print("What is 1+3=");
                // when I press 4 or other key, nothing happen..
                // so I assume that this getKey() not working in switch..
               if (key != NO_KEY)
                 if (key == '4')
                   lcd.setCursor(1,0);
                   lcd.print(key);
                   delay(2000);
                   lcd.clear();
                   lcd.setCursor(0,1);
                   lcd.print("Great Job!!!");
                   correct++;
                   lcd.print("Sorry.. try again");
meowcat
and one more thing..How to assign answer so that I can make if (key == answer)?
example,
int answer = 0;
int i, j;
i=random(4);
j=random(5);
lcd.print(i);
lcd.print("+");
lcd.print(j);
answer=i+j;
                if (key != NO_KEY)
                  if (key == answer) // how to do here?
                    //print something..
Nick Gammon
     if (key != NO_KEY)
       switch (key)
I said before "don't do two getKeys". You are doing two getKeys. Please review my earlier answer as to why.
As for the answer, you could turn the answer into ASCII like this:
answer  = i + j + '0';
More info:
Nick Gammon
Another approach, which would keep much of your existing design, is to make the getKey "block" like this.
Change:
to:
do {
} while (key == NO_KEY);
That makes the program wait in that spot until you actually press a key. Then you have a valid key to process.
More info:
