Topic: Arduino -Due SPI read and unexpected values (Read 349 times) previous topic - next topic
nagu3112
I am using Arduino-Due and interfaced a sensor using below SPI pins.
I read 1 byte of data from 0x80 register and did not get the expected value from the register when I read. (I get random values every time)
Could someone help to point out if I use the APIs properly?
HW:
MISO - Physical pin #108
MOSI - Physical pin #109
MSCK - Physical pin #110
CS1 - Physical pin #137
SW:
SPI_MODE0
1MHz Baud rate
I did not set the bit order
Arduino and sensor interfacing
#include <stdint.h>
#include <SPI.h>
#include <Wire.h>
const int slaveAPin = 4;
  sensor_spi_settings();
  sensor_chip_id();
void sensor_spi_settings(void)
  /* SPI Init */
  pinMode (slaveAPin, OUTPUT);
  digitalWrite(slaveAPin, HIGH);
  // initialize the bus for the device on pin 4
  SPI.begin(slaveAPin);
  SPI.setClockDivider(slaveAPin, 84);
  SPI.setDataMode(slaveAPin,SPI_MODE0);
void sensor_chip_id(void)
    uint8_t reg_adr;
    uint8_t reg_data;
    reg_adr = 0x80;
    SPI.transfer(slaveAPin,reg_adr,SPI_CONTINUE);
    reg_data = SPI.transfer(slaveAPin,0x00);
    Serial.print("Chip-ID : ");
    Serial.print(reg_data, HEX);
ard_newbie
What is the sensor you are actuelly using ? where is the link to the datasheet of the sensor ? did you read it ?
BTW, there is an example sketch of a sensor reading with SPI and an UNO that you could study and adapt to your needs with the DUE:
https://www.arduino.cc/en/Tutorial/BarometricPressureSensor
nagu3112
Thanks...
I use BMI088 sensor. I use the extended SPI APIs. I dont find a comple example with this version.
I have already seen this example as its part of the Arduino IDE.
Any further inputs?
