Topic: Handling series of AT commands to GSM shield (Read 419 times) previous topic - next topic
surepic
Yes you can treat it as false in if statement.
If(strstr(char array,"string to find"))
Will evaluate true if string is found and if not found will evaluate false.
PaulS
#16
Sep 26, 2018, 12:17 pm Last Edit: Sep 26, 2018, 12:18 pm by PaulS
Quote
Source of my confusion is, that I've read "Dereferencing a null pointer is undefined behavior in C".
Dereferencing means using a pointer to accomplish something. You should only do that after testing that the pointer is not NULL. You can ALWAYS compare a pointer to NULL (explicitly or implicitly).
Explicit:
Code: [Select]
char *haystack = "Needles all over the place";
if(strstr("needle", haystack) == NULL)
   // No needle in that haystack
Implicit:
Code: [Select]
if(!strstr("needle", haystack))
surepic
Strstr(actual string, string to search for)
So
Code: [Select]
If(!strstr("haystack",needle));
PaulS
So
Code: [Select]
Yeah, but that doesn't make any sense. 8)
Looking for a haystack in a needle?
surepic
#19
Sep 26, 2018, 01:01 pm Last Edit: Sep 26, 2018, 01:08 pm by surepic
Actual string is haystack. Needle is a string to be searched for. not opposite.
Char string[]="hello world";
Char needle[]="world";
Strstr(string,needle);
Thats what i meant.
But not strstr(needle,haystack).
