Topic: Serial Communication between XBee using Arduino (Read 2611 times) previous topic - next topic
Robin2
#15
Aug 20, 2018, 06:09 pm Last Edit: Aug 20, 2018, 06:18 pm by Robin2
By this way we can't print values
I don't understand that - what can you do? I have not used XBees myself. Do you mean that xbee.print() is not valid? If so, what is the correct syntax? My general understanding is that XBees just send serial data - but maybe I am wrong.
On the other hand maybe you can put your values into an array of ints and send that?
Can you post a link to the documentation for the Xbee library that you are using?
Quote
But, the place I got stuck with this is there are 6 XBee connected to each other and all are sending data to each other. Then how do we get to know that from which XBee we are getting our values?
Include in each message an ID number for the sender.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Priyanshu27
Quote
Link for the documentation:
https://github.com/andrewrapp/xbee-arduino
Quote
Yes, because there is no print function defined in xbee library.
Quote
Can you provide an example of it because I was not able to understand it?
I tried passing a message along with the random values to which I got an error message.
no matching function for call to 'HardwareSerial::print(uint8_t&, uint8_t&, uint8_t&)'
Robin2
#17
Aug 20, 2018, 07:53 pm Last Edit: Aug 20, 2018, 07:54 pm by Robin2
Thanks for the link. It's very irritating that there is no online documentation so I had to download the library. And the documentation is crap - it does not explain "send" at all. But there are some examples and it seems I have been barking up the wrong tree (not for the first time).
If you want to send (say) three numbers then create an array, make an XBee object with it, put the values you want into the array, and send the array. Like this, I think
Code: [Select]
int myArray[3];
ZBTxRequest zbTx5 = ZBTxRequest(ROUTER5, myArray, sizeof(myArray));
myArray[0] = thisXBeeID; //   I assume you will give each one a different number
myArray[1] = xVal;
myArray[2] = yVal;
xbee.send(zbTx5);
...R
PS ... where did you get the idea for such cryptic names for your variables :)
Priyanshu27
#18
Aug 20, 2018, 08:19 pm Last Edit: Aug 20, 2018, 08:28 pm by Priyanshu27
Quote
Sorry Man, I'm not an expert at coding. But, I'm trying to ask in the easiest manner I can.
Quote
I tried it earlier when I got an error.
Code: [Select]
uint8_t xy[3];
xy[0] = "XBeeId 1:";
xy[1]= rand()%100;
xy[2] = rand()%100;
Serial.print(xy[0],xy[1],xy[2]);
//Serial.print(xy[0]);
//Serial.print(",");
//Serial.print(xy[1]);
//Serial.println(xy[2]);
ZBTxRequest zbTx5 = ZBTxRequest(ROUTER5, xy, sizeof(xy));
xbee.send(zbTx5);
Error Message:
The output I want in return should be like in this format:
    XBeeId 1: 28,34
And same way I want to get at the receiver side.
Is it possible to print? Sorry for asking such silly questions.
Robin2
Error Message:
You need to post the complete program so we can see how all the variables are defined.
Quote
    XBeeId 1: 28,34
I don't believe there is any need for the style  XBeeId 1: 28,34. All that needs to be sent is 3 numbers in an array with no colons or commas or text. The receiving program will be written to expect that and everything will be much simpler.
...R
Priyanshu27
Quote
Code: [Select]
#include <XBee.h>
#include <stdlib.h>
#include <time.h>
XBee xbee = XBee();
XBee xbee1 = XBee();
XBeeResponse response = XBeeResponse();
ZBRxResponse rx = ZBRxResponse();
//XBeeAddress64 ROUTER1 = XBeeAddress64(0x0013A200,0X4147FE2A);
//XBeeAddress64 ROUTER2 = XBeeAddress64(0x0013A200,0x4147FE2B);
//XBeeAddress64 ROUTER3 = XBeeAddress64(0x0013A200,0x4147FE2E);
//XBeeAddress64 ROUTER4 = XBeeAddress64(0x0013A200,0x414E65AA);
XBeeAddress64 ROUTER5 = XBeeAddress64(0x0013A200,0x414E65AE);
XBeeAddress64 ROUTER6 = XBeeAddress64(0x0013A200,0x414E65B1);
//uint8_t sample;
uint8_t count = 0;
  xbee.setSerial(Serial);
  Serial.println("Stating Up!");
  Serial.println("Start Transmitting");
  srand((unsigned)time(NULL));
  uint8_t i = 0;
  uint8_t xy[3];
  //Serial.print("Data Sent: ");
  xy[0] = "XBeeId:";
  xy[1] = rand()%10;
  xy[2] = rand()%10;
  Serial.print(",");
  ZBTxRequest zbTx6 = ZBTxRequest(ROUTER6, xy, sizeof(xy));
  //sample = "";
  while(i<1)
    xbee.send(zbTx5);
    Serial.println("... To Router 5 ...");
    i++;
  xbee.readPacket(500);
  Serial.println("Packet Detected");
  Serial.print("count: ");
  Serial.println(count);
  if(xbee.getResponse().isAvailable())
    Serial.println("Packet Arrived");
    //Serial.println(xbee.getResponse().getApiId());
    if(xbee.getResponse().getApiId() == ZB_RX_RESPONSE)
      xbee.getResponse().getZBRxResponse(rx);
      Serial.print("Data Received: ");
      for(int i=0; i<rx.getDataLength(); i++)
        //sample+= (char)rx.getData(i);
        Serial.print(rx.getData(i),DEC);
      //Serial.println(sample);
      count++;
  else if(xbee.getResponse().isError())
    Serial.print("Error Reading Packet. Error Code: ");
    Serial.println(xbee.getResponse().getErrorCode());
Quote
Yeah, we don't need to style like this but by just sending three numbers there may be a possibility of reading wrong coordinates.
For example, suppose we sending data from Router 1 to Router 5 with a location of (2,34). So, the data received at Router 5 will be 1234. Here, we can say 1 stands for Router 1 but for the coordinates, we may read as (23,4) or (2,34). So we can read an incorrect location as well. How to get rid of that?
Robin2
Assuming the code in Reply #20 is what gave rise to the error message in Reply #18, I can't figure out what the problem might be without knowing the line number reported along with the error message. Post the complete error message.
Quote
There will be no ambiguity. On the receiving side there will also be an array with 3 elements. receivedData[0] will have the ID number; receivedData[1] will have the xValue and receivedData[2] will have the yValue. (Obviously you can choose your own array name)
...R
Priyanshu27
Quote
This was the complete error message:
error: no matching function for call to 'HardwareSerial::print(uint8_t&, uint8_t&, uint8_t&)'
Code: [Select]
      count++;
Quote
As you see in the code, we are getting the received data by using  (rx.getData(i), DEC). I guess, but not sure if it is getting data bit by bit or it taking data as a packet. So, can you suggest a way of getting a data packet in form of an array with three elements?
Robin2
#23
Aug 21, 2018, 10:06 am Last Edit: Aug 21, 2018, 10:06 am by Robin2
Somehow I think there is more. Never mind the fancy orange colour - just copy and paste the error message from the Arduino IDE.
Quote
I can't see because you have not posted the complete program.
And I presume you have realized that if you change the way you send data you also have to change the way it is received so that the receiving code matches the sending code.
Post the latest versions of your sending and receiving programs. There is no value looking at only one of them. That's like one-handed clapping.
...R
Priyanshu27
Quote
That was the entire error I was getting. I've copied and pasted it as it is. Just highlighted it with a fancy orange color so that you can see it.
Quote
If you see Reply #20, I've posted my complete updated code. However, in Reply #22 I posted on receiver code again because I wanted to ask problem from that part of the code.
Quote
If you see my entire code, as said by you to assign an ID no. to every router so that we can know from which router data is coming. But the issue I was facing on the receiver side is that we are getting data bit by bit and I'm not able to collect the data coming from the respective array into different arrays. If you can see the code and tell me how to create arrays at the receiving end and how to store the incoming data into it, it will be a huge huge help.
I'm attaching my complete code again just in case you face problem in going back and forth for different replies.
Code: [Select]
#include <XBee.h>
#include <stdlib.h>
#include <time.h>
XBee xbee = XBee();
//uint8_t sample;
uint8_t count = 0;
  uint8_t i = 0;
  uint8_t xy[3];
  xy[0] = "XBeeId:";
  xy[1] = rand()%10;
  xy[2] = rand()%10;
  Serial.print(",");
  //sample = "";
  while(i<1)
    xbee.send(zbTx5);
    i++;
      count++;
The data which we are taking at the receiver end is in this manner:
Code: [Select]
     for(int i=0; i<rx.getDataLength(); i++)          //This the loop for taking the receiving values.
        Serial.print(rx.getData(i),DEC);              //Here, we are printing the received value
      count++;
Robin2
Thank you for that.
However you seem to have posted the complete transmitting program but only part of the receiving program. Please post two complete programs.
And I remain sceptical about the completeness of your error message. I deliberately caused an error in a simple program and this is the message I got
Code: [Select]
ArduinoTemp.ino: In function 'void loop()':
ArduinoTemp.ino:22:20: error: 'low' was not declared in this scope
Error compiling.
You can see that it has identified the name of the program, the function where the error was and the line and character number where it was detected.
...R
Priyanshu27
Quote
There are no two codes as I'm using this code as the complete code. However, you may be finding the receiver code incomplete because I might have written an incomplete code for receiving the data. As my coding is not strong, I'm seeking help from the forum if I can get the completeness in my code.
Quote
And I remain skeptical about the completeness of your error message
Code: [Select]
#include <XBee.h>
#include <stdlib.h>
#include <time.h>
XBee xbee = XBee();
String sample;
uint8_t count = 0;
  uint8_t i = 0;
  uint8_t x = rand()%10;
  uint8_t y = rand()%10;
  uint8_t c = "XBeeId 1:";
  uint8_t data[] = {x,y};
  Serial.print(c,data[0],data[1]);
  //uint8_t data[] = "HI, I'M Router 5!";
  ZBTxRequest zbTx5 = ZBTxRequest(ROUTER5, data, sizeof(data));
  ZBTxRequest zbTx6 = ZBTxRequest(ROUTER6, data, sizeof(data));
  sample = "";
  while(i<1)
    xbee.send(zbTx6);
    Serial.println("To Router 6");
    i++;
  //String myString = "By Priyanshu";
  //data = atoi(myString.c_str());
  //char buf[myString.length()+1];
  //myString.toCharArray(buf, myString.length()+1);
  //data = ((uint8_t*)buf, strlen(buf));
      Serial.print("From Router 6: ");
        Serial.println(rx.getData(i),DEC);
      count++;
Try this code as I run on my machine and I'm getting this error. However, my objective from this error message is that at the transmitting end I'm able to send an ID no. but cannot differentiate that the coordinates I'm sending, how to figure it out.
As the random values, I'm generating as of now is between 0 to 9 just for the understanding purpose. But, in future, I shall be sending between 0 to 255 as there are in total 256 pixels of any color. So at that time how do we segregate the coordinates. Like the example, I gave earlier we are sending ID no. (say) 5 so we know it's ASCII value is 53 and the coordinates are (12,206). The output I'm getting is 5312206. So, how do we know if it is (12,206) or (122,06)? That's the problem I'm facing.
I know I've made it a big hype out of it, but as I mentioned my coding is not strong and this is an entirely new project for me so I'm facing a lot of challenges with it. You people being expert and thoroughly active on the forum to help the rookie coders might help me with it.
Robin2
You will make life a great deal easier for yourself if you create two separate programs - one for transmit and one for receive. At least do that until you are know how to get the communication working. Just make the simplest programs possible that will send and receive the data in the format you require.
It will also make it a great deal easier to help you.
When you have it working then you can combine the code into a single program if you wish.
...R
Priyanshu27
Hi Robin, I've resolved all the previous problems and now the data was transmitting the way I wanted. There was a change in the requirement of the project as earlier I was sending a broadcasted message, now I need to send as a unicast message. Means that now we have to take value from the user to send the message to the desired router. This thing should be done autonomously which I shall be seeing when an actual sensor is attached instead of generating a random number.
I used a help from your topic on "Serial Input Basics - updated" which helped me in taking input from the serial monitor and I must say it was a great help.
Now, the problem I'm facing is that at the time of taking input in the XBee mode of the Sainsmart Arduino-XBee Shield which is used to communicate between XBee and Arduino. Whatever, input I'm taking is not getting displayed on the serial monitor. So, my question is, do we have to apply a similar code at the receiving end just like we did at the transmitting end or that code works fine and I'm doing mistake at somewhere else.
I'm attaching my code for your reference.
Code: [Select]
#include <XBee.h>
#include <time.h>
#include <stdlib.h>
XBee xbee = XBee();
XBeeAddress64 ROUTER1 = XBeeAddress64(0x0013A200,0x4147FE2A);
uint8_t count = 0;
uint8_t input = 0;
String sample = "";
  transmitXBee();
  receiveXBee();
void transmitXBee()
  uint8_t i = 0;
  uint8_t data[3];
  uint8_t receivedChar = '0';
  boolean newData = false;
  data[0] = '6';
  data[1] = rand()%256;
  data[2] = ',';
  data[3] = rand()%256;
  ZBTxRequest zbTx1 = ZBTxRequest(ROUTER1, data, sizeof(data));
  ZBTxRequest zbTx2 = ZBTxRequest(ROUTER2, data, sizeof(data));
  ZBTxRequest zbTx3 = ZBTxRequest(ROUTER3, data, sizeof(data));
  ZBTxRequest zbTx4 = ZBTxRequest(ROUTER4, data, sizeof(data));
  Serial.print("Data Sent:\t");
  Serial.print(data[0]);
  Serial.print(data[1]);
  Serial.print(data[2]);
  Serial.println(data[3]);
  if (Serial.available() > 0)
    receivedChar = Serial.read();
    newData = true;
  if (newData == true)
    Serial.print("Input: ");
    Serial.println(receivedChar);
    newData = false;
    switch(receivedChar)
      case '1':
        Serial.println("To Router 1");
        xbee.send(zbTx1);
      case '2':
        Serial.println("To Router 2");
        xbee.send(zbTx2);
      case '3':
        Serial.println("To Router 3");
        xbee.send(zbTx3);
      case '4':
        Serial.println("To Router 4");
        xbee.send(zbTx4);
      case '5':
        Serial.println("To Router 5");
        xbee.send(zbTx5);
      default:
        Serial.println("Wrong input entered");
void receiveXBee()
  Serial.println("Reading for Packet");
    Serial.print("Packet Available: ");
      delay(300);
        sample += (char)rx.getData(i);
        //Serial.print(rx.getData(i),DEC);
      count++;
      Serial.print("Packet Received: ");
      delay(1500);
Robin2
I have several times asked you to post BOTH the sending and the receiving code. Without seeing both how can I answer your question.
...R
