Hi everyone.
Right I have my project all set up ...but... I need power, I thought it would be easy but after later calculations its harder than I thought.
Soo 12v in a car isn't usually 12v for very long at all. 14.4v or thereabouts whilst the engine is running and about 8v while the car is starting up etc.
I thought about using an in car charger that outputs 5v but i found out the one I have outputs 700ma which means my car battery would only last about 62 hours (about 2 and a half days).
Could I not use a voltage divider to take the 12v and convert it to 5v? Well something like this:
Vin: 14v | R1: 5KOhm | R2: 3KOhm | Vout: 5.25v = Power dissipated by circuit = 24.5mW (Which works out at about 2mA? Correct?)
Vin: 8v | R1: 5KOhm | R2: 3KOhm | Vout: 3v = Power dissipated by circuit = 8mW (Which works out at about 1mA? Correct?)
^ That info was calculated using Electrodroid for Android
So in this case, would it be okay to use a voltage divider or is it not such a good idea?
I have the arduino, an RF receiver board and a bluetooth board to power (RF board is taking power from an arduino pin thats set High and the bluetooth is using the arduino's 3.3v supply.)
Any help is much appreciated.
Thanks.
