Topic: Arduino Due with watch timer and interrupt reset (Read 528 times) previous topic - next topic
Narate
I'm newbie about the Arduino Due.
I'm want to use the interrupt when the program deadlock. Now I can enable the watchdog timer but how to use the interrupt function?
Anyone please help me..
The code are below.
#define WDT_KEY (0xA5)
void watchdogSetup(void) {/*** watchdogDisable (); ***/}
  // Enable watchdog.
  WDT->WDT_MR = WDT_MR_WDD(0xFFF)
                | WDT_MR_WDRPROC
                | WDT_MR_WDRSTEN
                | WDT_MR_WDFIEN
                | WDT_MR_WDV(256 * 2);
  uint32_t status = (RSTC->RSTC_SR & RSTC_SR_RSTTYP_Msk) >> 8; // Get status from the last Reset
  Serial.print("RSTTYP = 0b"); Serial.println(status, BIN);  // Should be 0b010 after first watchdog reset
  //Restart watchdog
  WDT->WDT_CR = WDT_CR_KEY(WDT_KEY)
                | WDT_CR_WDRSTT;
  Serial.println("Enter the main loop : Restart watchdog");
  while (true)
    Serial.println("the software becomes trapped in a deadlock !");
ard_newbie
This example sketch uses watchdog interrupt Handler but do not reset the uc:
Code: [Select]
void watchdogSetup(void) {}
  // Enable watchdog.
  WDT->WDT_MR = WDT_MR_WDD(0xFFF) |
                WDT_MR_WDFIEN |      //  Triggers an interrupt or WDT_MR_WDRSTEN to trigger a Reset
                WDT_MR_WDV(256 * 2); // Watchdog triggers a reset or an interrupt after 2 seconds if underflow
  // 2 seconds equal 84000000 * 2 = 168000000 clock cycles
  /* Slow clock is running at 32.768 kHz
    watchdog frequency is therefore 32768 / 128 = 256 Hz
    WDV holds the periode in 256 th of seconds  */
  NVIC_EnableIRQ(WDT_IRQn);
  Serial.begin(250000);
  uint32_t status = (RSTC->RSTC_SR & RSTC_SR_RSTTYP_Msk) >> RSTC_SR_RSTTYP_Pos /*8*/; // Get status from the last Reset
  //Restart watchdog
                | WDT_CR_WDRSTT;
  GPBR->SYS_GPBR[0] += 1;
  Serial.print("GPBR = "); Serial.println(GPBR->SYS_GPBR[0]);
  while (true)
    /* If the software becomes trapped in a deadlock,
       watchdog triggers a reset or an interrupt. if there is a reset, the software restarts with stored values
       in General Purpose Back up Registers*/
void WDT_Handler(void)
  WDT->WDT_SR; // Clear status register
  printf("help! in WDT\n");
Narate
