Loading...
Pages: [1]   Go Down
Author Topic: Red light frequency  (Read 511 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Hi, I'm looking on how can i read the speed of a shutter with a digitalread and a light sensor... The idea is to be able to know how many RPS I'm using on the shutter.
The shutter is placed in front of the light, so i can read just ON and OFF of the light and calulate how many I have in a second.. and write it on a small LCD.
So, did someone know wich sensor i can use to work on this project??
Best
KinoLab
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I'd use a photodiode.
(your thread title isn't very descriptive of the problem IMHO)
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Upss smiley-fat  sorry I haven't see the mistake...
thanks for your answer and did you think that a photo diode can read a frequency of around 72 input for second?
best
Ki
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
72Hz is not a problem for a photodiode.
« Last Edit: March 25, 2011, 09:08:10 am by AWOL » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
photodiodes will typically handle MHz - phototransistors may be a bit slower due to storage effects.  For really high speed a PIN diode is used.  72Hz is no problem.  LDRs can be very slow though, don't bother with them.
If the light levels are fairly fixed you may get away with chosing a load resistor that can directly produce logic level outputs and you might be able to use pulseIn - however to do this properly a schmidt-trigger gate might be a good idea.   analogRead() take some time (100us??) but ought to be fast enough here.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Thanks for all your answers...
In general the speed will be really precise and constant, is for a 16mm projector, so the idea is to be able if is a 24 ips or if it change to 23.90 or what else...
The ply problem is that i'm not so familiar with electronic and did you some photos on how use a PIN DIODE ?
sorry and thanks
KinoLAb
Logged
Pages: [1]   Go Up
Print
Jump to:
