Topic: Robot - problem (Read 2363 times) previous topic - next topic
elmar
hy @ all,
i´m just a arduino beginner on his first steps...after solving a few problems with my arduino i wanted to build a small "robot".
For that i wanted to use an old RC-Toy Tank, i want to use a few parts of it and an arduino plus a few servos to build my little robot.
The RC Tank was disassembled so that we get the driving unit and all the electronic parts.  We don´t change anything in the driving section so that it can be operated from the Remote of the RC Tank (so that our robot can drive forward backward etc), the Tank Remote has another channel to control the upper part with the gun of the tank. Originally the Tank could rotate it´s upper part and fire small airsoft bullets. We disconnected the small dc motor which fires the bullets to get its signal. Then we connected the + to digital pin2 and - to ground. (tryed it before with a switch on pin2 and 5V+ and a resistor connected to ground and it worked fine). We hoped that we can get this signal to controll a few movements of the servos which are connected to the arduino. (everytime pin2 gets high is counted and on every count something happens)
The Servos are connected to digital pin 9-11, but only one of them was attached for the test today and they got their own power source.
now to my problem....
with a button connected to pin2 everything works fine....everytime i press the button my servo moves to the next position....but when i connect the r/c electronic to my arduino i only press the button of the r/c remote 1 time and the complete program cycles through, over and over again.
I already tested the r/c electronics with a led connected to the wires which go to the arduino and the result is that the led only turns on as long as i press the button...so maybe there is an error in my code ???
Code: [Select]
#include <Servo.h>
const int buttonPin = 2;
Servo myservo;   // create servo object to control a servo
Servo arml;
Servo armr;
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState     = 0;  // current state of the button
int lastButtonState = 0;  // previous state of the button
int pos     = 0;  // variable to store the servo positions
void setup() {     // initialize serial communication:
  myservo.attach(9); // attaches the servo on pin 8 to the servo object
  myservo.write(0);  // set servo to zero
arml.attach(10);
armr.attach(11);
arml.write(0);
armr.write(0);
  pinMode(buttonPin, INPUT);  // initialize the button pin as a input
  buttonState = digitalRead(buttonPin); // read the pushbutton input pin
  if (buttonState != lastButtonState) { // compare buttonState to previous state
  if (buttonState == 1) {     // if the current state is 1 then the button
                              // went from off to on:
    buttonPushCounter++;
    Serial.println("on");
    Serial.print("number of button pushes:  ");
    Serial.println(buttonPushCounter, DEC);
                              // do something different depending on the
                              // range value:
    switch (buttonPushCounter) {
case 1:               // If the button count is at 1
Serial.println("1");     // print 1
myservo.write(180);   // tell servo to go to position 'pos'
delay(500);   // waits 0.5s for the servo to reach the position
arml.write(35);
        armr.write(35);
case 2:     // If the button count is at 2
Serial.println("2");     // print 2
  myservo.write(90);   // tell servo to go to position 'pos'
arml.write(60);
        armr.write(60);
case 3: //if the button count is at 3
Serial.println("3");
myservo.write(0); // tell servo to go to position 'pos'
arml.write(45);
        armr.write(45);
case 4:  // if the button count is 4
Serial.println("4");
myservo.write(144); // tell servo to go to position 'pos'
arml.write(75);
        armr.write(75);
case 5:  //if the button count is 5
Serial.println("5");
arml.write(90);
        armr.write(90);
case 6:  //if the button count is 6
Serial.println("6");
                          // reset everything.
myservo.write(0); // tell servo to go to position '0'
delay(1000);      // waits 1 second for the servo to reach the position
arml.write(0);
        armr.write(0);
                          // reset the push button count to 0
buttonPushCounter = 0 ;// Now everything is set back to the way we started.
johnwasser
After you check for (buttonState != lastButtonState) your forgot to say:
Code: [Select]
lastButtonState = buttonState;
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
elmar
thanks a lot !! that already helps a bit  :)
but when i add that line, i got the result that the servo turns to the first position when i press the button on the rc remote, the second time i press the button nothing more happens instead of turning the servo to its next position ??
and here is the updated code
Code: [Select]
#include <Servo.h>
Servo arml;
Servo armr;
arml.attach(10);
armr.attach(11);
arml.write(0);
armr.write(0);
                              // range value:
arml.write(35);
        armr.write(35);
arml.write(60);
        armr.write(60);
arml.write(45);
        armr.write(45);
arml.write(75);
        armr.write(75);
arml.write(90);
        armr.write(90);
arml.write(0);
        armr.write(0);
johnwasser
The code looks fine to me.  So the last thing that comes out on the serial monitor is '1'?  Either I missed something in the code, or your problem is in hardware, or you ran out of memory.  Try removing the "number of button pushes:   " string to free up some memory.
elmar
Quote
yes, totally right
First press of the button - serial responds with the count 1 and the servo moves to the first position
second press - nothing happens on serial monitor - servo stands still on position 1
something curious which i noticed while trying out a few things to correct the problem....
if i turn the r/c electronic off and on again and press the button for another time - the servo moves to the second position and the serial monitor show me the 2nd count....but again only 1 time...another press of the button does nothing until i redo the complete power off/on procedure....
MarkT
Perhaps the RC output needs a pull-down resistor?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
