Loading...
Pages: 1 [2]   Go Down
Author Topic: What size capacitor needed to power solenoid?  (Read 1682 times)
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Well, It is unlikely to see fireworks on a circuit that supply just 50 Amps, probably even less.
I know, that Capacitive Discharge Spot Welder delivers >2000 Amps in the same time frame.
http://www.shearconnectorwelding.com/capacitor-welding-machines.html
http://www.philpem.me.uk/elec/welder/
http://ultrakeet.com.au/index.php?id=article&name=cdWelder
And there is a link to capacitor selection tab:
http://frikkieg.blogspot.com/p/capacitor_04.html
Plus video:
http://frikkieg.blogspot.com/2009/06/homemade-capacitor-spot-welder.html
Logged
Fort Worth, Texas
Offline Offline
Newbie
View Profile
I have reconsidered the capacitor vs. battery solution. I don't want a capacitor exploding inside my control box. I do have a few SLA batteries laying around I can use...20ah capacity. I would rather use a 12v trickle charger to maintain the battery and keep this part of the project separate from other power needs (stepper motor and Arduino). Terry, I don't have an Oscope, but will take your advice and use a suitable diode across the solenoid terminals. As for switching...do you prefer the FET board over using a SSR good for 40 or 60 amps? As you mentioned, pulling 40 amps in 50ms isn't going to happen.
Thanks,
Cris
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Not sure what planet you are on but 50 Amps is a lot of current on this one. You can get quite spectaular with that amount of current.
Quote
And did you see the size of those things, they weren't cobbled together by an amateur.
Logged
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
I As for switching...do you prefer the FET board over using a SSR good for 40 or 60 amps? As you mentioned, pulling 40 amps in 50ms isn't going to happen.
If you can get a DC type SSR like that it sounds like a good solution..
Let us know what works out so we learn too  smiley-cool
Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
Fort Worth, Texas
Offline Offline
Newbie
View Profile
Well I ordered a Chinese build 40 amp DC to DC SSR, but I'm going to order that FET board as well...I'll try out both and report back on how things work out.
Thanks,
Cris
Logged
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
Turn-on time for a DC SSR will be considerable slower than a FET.  This might have a bearing on how quickly you can get the required energy into your solenoid, the inductance of which will itself tend to slow down the current in-rush.
Logged
Bute, Scotland
Offline Offline
Jr. Member
View Profile
Came across these today. U.K supplier :
http://www.distel.co.uk/Asps/details1.asp?ID=HP23
The coil on these is low current but you could drive them in series from the 24 volts without the 24 to 12 volt conversion and with contacts on the relays in parallel
from a relatively low power transistor I think.
Logged
Fort Worth, Texas
Offline Offline
Newbie
View Profile
Well, I was trying to stay away from a mechanical relay. Received the SSR I ordered from the west coast and it pulls the solenoid in pretty good, only problem is my Arduino doesn't have the power to pull in the SSR! Now I've got to either use a power transistor or reed relay to pull in the SSR..... Just added more complexity to the whole thing.
Cris
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
