Loading...
Pages: [1]   Go Down
Author Topic: arduino mega + sd card connected with resistor  (Read 1254 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
hi,
i m try to write on my sd card connected with resistor to arduino
i try this : http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206874649/0
but i have may errors at compiling :
arduino sd card example.cpp:1:30: error: sd-reader_config.h: No such file or directory
arduino sd card example.cpp:2:20: error: sd_raw.h: No such file or directory
arduino sd card example.cpp:3:27: error: sd_raw_config.h: No such file or directory
arduino sd card example.cpp:13: error: 'byte' does not name a type
arduino sd card example.cpp:16: error: 'byte' does not name a type
arduino sd card example.cpp: In function 'void setup()':
arduino sd card example.cpp:22: error: 'Serial' was not declared in this scope
arduino sd card example.cpp:23: error: 'delay' was not declared in this scope
arduino sd card example.cpp:26: error: 'sd_raw_init' was not declared in this scope
arduino sd card example.cpp: In function 'void loop()':
arduino sd card example.cpp:39: error: 'Serial' was not declared in this scope
arduino sd card example.cpp:41: error: 'incomingByte' was not declared in this scope
arduino sd card example.cpp: In function 'int sample()':
arduino sd card example.cpp:61: error: 'byte' was not declared in this scope
arduino sd card example.cpp:61: error: expected `;' before 'low'
arduino sd card example.cpp:62: error: expected `;' before 'high'
arduino sd card example.cpp:63: error: expected `;' before 'inByte'
arduino sd card example.cpp:65: error: 'Serial' was not declared in this scope
arduino sd card example.cpp:72: error: 'inByte' was not declared in this scope
arduino sd card example.cpp:75: error: 'analogRead' was not declared in this scope
arduino sd card example.cpp:76: error: 'DEC' was not declared in this scope
arduino sd card example.cpp:80: error: 'low' was not declared in this scope
arduino sd card example.cpp:81: error: 'high' was not declared in this scope
arduino sd card example.cpp:86: error: 'tempBytes' was not declared in this scope
arduino sd card example.cpp:89: error: 'sd_raw_write' was not declared in this scope
arduino sd card example.cpp:94: error: 'delay' was not declared in this scope
arduino sd card example.cpp: In function 'int readDisk()':
arduino sd card example.cpp:106: error: 'byte' was not declared in this scope
arduino sd card example.cpp:106: error: expected `;' before 'low'
arduino sd card example.cpp:107: error: expected `;' before 'high'
arduino sd card example.cpp:108: error: expected `;' before 'info'
arduino sd card example.cpp:111: error: 'Serial' was not declared in this scope
arduino sd card example.cpp:114: error: 'info' was not declared in this scope
arduino sd card example.cpp:114: error: 'sd_raw_read' was not declared in this scope
arduino sd card example.cpp:119: error: 'low' was not declared in this scope
arduino sd card example.cpp:120: error: 'high' was not declared in this scope
arduino sd card example.cpp:124: error: 'DEC' was not declared in this scope
arduino sd card example.cpp: In function 'void printWelcome()':
arduino sd card example.cpp:132: error: 'Serial' was not declared in this scope
arduino sd card example.cpp: In function 'int print_disk_info()':
arduino sd card example.cpp:146: error: aggregate 'sd_raw_info disk_info' has incomplete type and cannot be defined
arduino sd card example.cpp:147: error: 'sd_raw_get_info' was not declared in this scope
arduino sd card example.cpp:153: error: 'Serial' was not declared in this scope
arduino sd card example.cpp:155: error: 'HEX' was not declared in this scope
arduino sd card example.cpp:161: error: 'DEC' was not declared in this scope
What does it mean?
I have copied the library SDcard in  libraries
my board is the mega 1280
Logged
Espoo, Finland
Offline Offline
God Member
"Oops, try again..."
View Profile
Code is missing.
Cheers,
Kari
Logged
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
0
Offline Offline
Newbie
Arduino rocks
View Profile
the code is here :
le library is on this post : http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206874649/0
Code:
#include <sd-reader_config.h>
#include <sd_raw.h>
#include <sd_raw_config.h>
int print_disk_info();
int sample();
int readDisk();
byte incomingByte;
void printWelcome();
long int address;
byte tempBytes[2];
  printWelcome();
  if(!sd_raw_init())
     Serial.println("MMC/SD initialization failed");
  print_disk_info();
    int i;
    if(Serial.available()>0)
       incomingByte=Serial.read();
     switch(incomingByte)
         case 114:
               readDisk();
         case 115:
               sample();
         default:
int sample()
    int i,j;
    int temp;
    byte low;
    byte high;
    byte inByte;
    Serial.println("Sampling..");
    for(i=0;i<500;i=i+2)
        inByte=Serial.read();
        if(inByte==113) return 0;
      temp=analogRead(0);
      Serial.print(temp,DEC);
      Serial.print(" ");
      //Convert int to 2 bytes
      low=temp&0xFF;
      high=temp>>8;
     // Serial.print(temp,DEC);
      //Serial.print(low,DEC);
      //Serial.print(high,DEC);
      tempBytes[0]=low;
      tempBytes[1]=high;
      if(!sd_raw_write(i,tempBytes,2))
        Serial.print("Write error");
      //sd_raw_sync();
      delay(5000);
    return 1;
int readDisk()
    byte low;
    byte high;
    byte info[2];
    int i;
    int  result;
    for(i=0;i<50;i=i+2)
      sd_raw_read(i,info,2);
      //Serial.print(info[0],DEC);
      //Serial.print(" ");
      //Serial.print(info[1],DEC);
      low=info[0];
      high=info[1];
      result=high<<8;
      //result<<8;
      Serial.print(" ");
      Serial.print(result+low,DEC);
      Serial.print(" ");
void printWelcome()
    Serial.println("------------------------");
    Serial.println("Data sampling system");
    Serial.println("send r to read disk");
    Serial.println("send s to start sampling");
    Serial.println("send q to stop sampling");
    Serial.println("Ready.....");
    Serial.println("-------------------------");
    struct sd_raw_info disk_info;
    if(!sd_raw_get_info(&disk_info))
      return 0;
    Serial.print("rev:    ");
    Serial.print(disk_info.revision,HEX);
    Serial.print("serial: 0x");
    Serial.print(disk_info.serial,HEX);
    Serial.print("date:   ");
    Serial.print(disk_info.manufacturing_month,DEC);
    Serial.print(disk_info.manufacturing_year,DEC);
    Serial.print("size:   ");
    Serial.print(disk_info.capacity,DEC);
    Serial.print("copy:   ");
    Serial.print(disk_info.flag_copy,DEC);
    Serial.print("wr.pr.: ");
    Serial.print(disk_info.flag_write_protect_temp,DEC);
    Serial.print('/');
    Serial.print(disk_info.flag_write_protect,DEC);
    Serial.print("format: ");
    Serial.print(disk_info.format,DEC);
    Serial.print("free:   ");
    return 1;
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
#include <sd_raw.h>
Quote
Well, it would seem that you have failed to download/properly install some libraries.
Logged
Pages: [1]   Go Up
Print
Jump to:
