Topic: Substitute for a reed switch? (Read 3644 times) previous topic - next topic
polishdude20
Well I'm making an RPM meter for my bike and I was just wondering if thee is something else I can use to trigger the  rotation instead of a reed switch?
cr0sh
You could use a hall-effect sensor; you could also use an optical sensor of some sort (you would likely need to use modulated IR light to prevent interference from external light sources)...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
TerryKing
If you're trying to find a local supplier, look for a "window switch" for alarm systems: Radio Shack or your local alarm guy??
They are usually a magnet and reed switch...
GaryP
Polishdude20,
Try to keep this conversation, that obviously is connected to one subject, inside one topic. Now it has been broken at least into four places.
Don't create more topics anyway.
Sorry about the nagging, but that is a bit annoying when I'm following the project to proceed.
But to the question.
Reedswitch and hallsensor, both needs magnet to trigger. Mechanical switches are not good choice, noise, worn issues...
What is left, optical was mentioned.
IR encoder wheel near the axel is nice, but the dust and dirt is not. But can be covered any how.
One thing you are still missing in your project is to follow how fast rider is moving his/her legs, pedals(?), what is that part???
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
jackrae
The obvious question -
Why don't you want to use a reed switch ?   They are simple, cheap and utterly reliable
mowcius
Quote
Dunno what reliable reed switches you have - they're simple, cheap, made of glass, mechanical switches which need debouncing.
Hall effect switches are almost as cheap and are rather more reliable.
pwillard
Quote
made of glass
Fragile.   I've replaced a few that were not in the correct "environment" for a GLASS based device.
polishdude20
well I found a good supplier (bgmicro) and their shipping is great so I might just get some reed switches from them after all and maybe a hall effect sensor.
Gary about the riders legs, who said I will be measuring the riders leg speed? Cause I'll just be measuring the wheel revolutions.
GaryP
Now, use your head before answering. It is an option. But if you don't know that you might need it, then you probably don't.
That would give you something you don't think at a moment, one extra information.
Cheers,
Kari
retrolefty
Quote
But what if he wants to pedel other then due north. ?
mowcius
Quote
Lefty you make me smile :)
retrolefty
Quote
Great, does that mean you got over that revolution (1776) thing between us.  ;)
Lefty
mowcius
Quote
That what thing? Did we have a thing going on? That thing?  :P
Hauge
A ABS VR-sensor rescued from a scrapped car maybe ?
thegeekway
Quote
Lefty
We consider you our wife, we just let you think you got the upper hand ;)
