Topic: Quick compatibility question. (Read 836 times) previous topic - next topic
polykarbon
Is the DEV-09815 motor shield from sparkfun compatible with the Arduino Mega 2560? Does the DEV-09815 require any protection from back EMF if I'm powering the Tamiya dual motor gearbox? Thank you.
RuggedCircuits
Yes, it should be. Digital lines 3 and 11 are used for PWM and both those pins are PWM-capable on the Uno and the Mega2560.
Back-EMF protection is provided by 8 diodes on the shield so no additional protection should be needed.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
polykarbon
Thank you for your reply, much appreciated.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
