Loading...
Pages: [1]   Go Down
Author Topic: Brushless motor control via Serial  (Read 751 times)
0
Offline Offline
Newbie
View Profile
I'm trying to drive a brushless motor via an ESC which worked fine, now I am trying to have it read data from serial and control the motor with the serial data but I'm having a problem.
After it inits it sits there idle, then after sending a value to the com port it goes to the speed for the duration of Delay() but then no more.
The code is messy (I haven't done a whole lot with the Arduino) as it's got bits and pieces from different projects/posts
Code:
// this uses the Arduino servo library included with version 0012
// caution, this code sweeps the motor up to maximum speed !
// make sure the motor is mounted securily before running.
#include <Servo.h>
int serspeed = 0;
Servo myservo;
void arm(){
  // arm the speed controller, modify as necessary for your ESC
  setSpeed(30);
  delay(1000); //delay 1 second,  some speed controllers may need longer
void setSpeed(int speed){
  // speed is from 0 to 100 where 0 is off and 100 is maximum speed
  //the following maps speed values of 0-100 to angles from 0-180,
  // some speed controllers may need different values, see the ESC instructions
  int angle = map(speed, 0, 100, 0, 180);
  myservo.write(angle);
  myservo.attach(12);
  arm();
  pinMode(serspeed, OUTPUT);
    serspeed = Serial.read();
    setSpeed(serspeed);
Logged
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
I think you need to check if Serial has data available. Otherwise your SerialRead may return 0??
Let us know!
Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
0
Offline Offline
Newbie
View Profile
It has to have some data because the first value I enter starts it up for the delay period.
I'm using the serial monitor in arduino.  How can I check to make sure it is sending?
Logged
Pages: [1]   Go Up
Print
Jump to:
