Loading...
Pages: [1] 2   Go Down
Author Topic: uLCD-144 4D problem with Duemilanove  (Read 1449 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have a uLCD-144 from 4D. It works without problems with an arduino Mega2560, but it fails with Duemilanove.
It is very simple to manage: it uses serial communication to send some specific command. For instance, to inizialize it you have to send 0x55 and it should respond with 0x06 (ACK).
I wrote a simple sketch that send 0x55 and wait for something from serial and in the mega2560 it works, but in duemilanove doesn't.
I can't understand why...
Thank you!
Andrea
Logged
Espoo, Finland
Offline Offline
God Member
"Oops, try again..."
View Profile
Code...
Kari
Logged
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
0
Offline Offline
Newbie
Arduino rocks
View Profile
Sorry smiley
Code:
   Serial.write(0x55);
   while(!Serial.available());
   Serial.print(Serial.read(), HEX);
Logged
Espoo, Finland
Offline Offline
God Member
View Profile
Then it must be physical coneection problem, or broken device.
Kari
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I agree...
but the same display works with the same code in the mega2560. And I tried it with two duemilanove and it doesn't work...
Thank you
Andrea
Logged
Espoo, Finland
Offline Offline
God Member
View Profile
I was talking about the Duemilanove...
 smiley-wink
It's time to check your circuit, could you show us how it is put together?
Cheers,
Kari
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
That's how I connect the display:
Display          Arduino
5 (RES)          RESET
6 (GND)          GND
7 (RX)             TX
8 (TX)             RX
9 (VIN)            +5
Thank you
Logged
Espoo, Finland
Offline Offline
God Member
View Profile
What comes to my mind is that your TX and RX are swapped, could it be?
Kari
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
Do you have the USB plugged in at the same time? Try disconnecting it.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
Yes, it is right, because the display tx and rx are from "the display point of view"...
Quote
I tried but nothing change...
It is unbelievable!
Same code, same wiring! I just move wires from the mega to the duemilanove!
Thank guys for your time!
Logged
Espoo, Finland
Offline Offline
God Member
View Profile
Sorry smiley
Code:
   Serial.write(0x55);
Now I must ask, what this does, and is this really everything?
Kari
« Last Edit: March 27, 2011, 01:26:50 pm by GaryP » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
In this pdf:
http://www.4dsystems.com.au/downloads/Serial-Display-Modules/uLCD-144(SGC)/Docs/uLCD-144-SGC-DS-rev1.pdf
at page 10 they said to wait up to 500ms from reset to send the autobaud command (0x55) so I wait 1s. The display waits until 5s for this command.
Then the display should answer with the ACK (0x06), so I wait for that.
Thank you
Logged
Espoo, Finland
Offline Offline
God Member
View Profile
Display          Arduino
5 (RES)          RESET
6 (GND)          GND
7 (RX)             TX
8 (TX)             RX
9 (VIN)            +5
Thank you
What pin numbers actually, in both cards, mega and duemilanove?
Kari
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Pin numbers are the same in both cards:
0 for RX
1 for TX
I can't really understand...
Thanks kari!
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Which of the four USARTS in the Mega2560 are you using to communicate with your uLCD-144?  Is it the same one that is used by the bootloader to download your sketches?  In the Duemilanove there is only one USART which is used for both purposes, and therein may lie the reason for the differences in operation.
Don
Logged
Pages: [1] 2   Go Up
Print
Jump to:
